Old 1st March 2014, 12:17 PM
Well I think so, but I'll reseal it again when we get some warm dry weather.
Just looked now and there's still some water getting in somewhere. Though I still have the rectangular grommet out so not much can accumulate.
Old 1st March 2014, 02:15 PM
Originally Posted by Simon Wallwork View Post
Are you sure the repair to the grommet nearest the rear windscreen, on the off side, is good?
I tried absolutely everything imaginable before tracing the fault to that one grommet.
My boot lid fills up regularly and its one of the spring/summer jobs i need to get around to. I my case - and having followed this subject for a while - the cause appears to be the perished grommet. But I have to say I am not sure how the amount of water that gets in the lid (a good 1/2 pint) manages to pass upwards through the grommet.
Old 5th March 2014, 01:25 PM
I've just been looking at that again, and literally SMOTHERING the entry hole, grommet and pipe with mastic.
I reckon it's the geometry of the roofline and drainage channel; it's seemingly designed that rain swept off the roof is caught by the leading edge of the boot and is supposed to go downwards and exit via the channels either side of the boot lid.
As such it's likely that a lot of water will hit that precise area.
Old 26th April 2014, 02:43 PM
Just opened my boot and water poured out as it got vertical!
The cable grommets are both VERY well sealed.
At the bottom edge the central rectangular grommet is open, the round ones at each corner are in place. I popped them out and both were wet behind.
So water is getting in somehow and accumulating at the rear lower edge, limited as I have the central grommet missing.
Look as hard and logically as I can I can't think realistically how.
One possibility is that rain is somehow coming in under the front edge between the rubber seal and the lid, then working up inside the lid. But I would then expect to see water in the boot, and there's none.
The only other area is around the lights and numberplate, but again it all looks well-sealed and could only be rain trickling in while parked.
Old 24th May 2014, 04:59 AM
bobbygd bobbygd is offline
Easy way is to get some clear silicone and go round all the bolts on the lights and make sure you do the strip that holds the number plate lights as well, Take the nuts off and put some goo on then put the nuts back on. 2 years running and mine is still dry.
affiliate marketing programs
Old 14th August 2015, 11:47 AM
Old thread but I had some useful input on this at Audi In The Park last weekend.
Talking to someone with a D2 (not sure who, not a regular here, but uses our sponsors a fair bit if I'm recalling the right person) who said he solved his problem by sealing around the numberplate mounting panel.
He spent ages trying to trace the source of the leak and eventually worked out that rain was running down the back of the boot lid and in the top edge of the numberplate recess surround.
He just filled it all the way round with mastic - very neatly as I didn't even notice until he pointed it out - but I'd rather do it "properly".
Mine is still a bit of an annoyance. Anyone know how that area is dismantled so that it can be reseated and sealed correctly?
Old 14th August 2015, 12:51 PM
When the boot lid of one of my previous D2 '8s kept filling with rain water, some years ago, the cause was a perished light-cluster seal, though I can imagine how a badly sealing numberplate surround could cause the same issue. In my case, I fixed it my removing the light cluster and fitting a new seal.
Old 14th August 2015, 01:07 PM
I'm pretty sure I've eliminated the light clusters and cable grommets, hence the question about the numberplate surround.
Old 4th October 2015, 04:58 PM
... someone with a D2 (not sure who, not a regular here, but uses our sponsors a fair bit if I'm recalling the right person) who said he solved his problem by sealing around the numberplate mounting panel.
................. Anyone know how that area is dismantled so that it can be reseated and sealed correctly?
I'm hoping to look at this in the next few days, so before I "dive in" can anyone offer any practical experience of dismantling this area of the boot lid?
(I've had the lining off several times so know that process, but is that required?)
Old 15th July 2017, 12:49 PM
johnny_quattro's Avatar
Default More H20
What with the recent inclement weather including some rather torrential downpours, I've been welcomed by at least a pint of water when opening the boot of my A8L. Those of you in-the-know will suspect that loud amplified stereo equipment of the conical variety may have something to do with it. My sub seems to be capable of not only rattling the windscreen wipers but also makes the boot and especially the number plate holder area vibrate.
I have already had to replace both inner rear light lenses and the current ones are cracked, but only on the reversing light part - the red part seems unaffected. I will also be checking the grommets and attacking them with sealant. The situation is so bad that I've had to take the furry access covers off of the inside lights in order to drain the water out, which happens automagically when I lift the boot lid up. Thanks to all prior posters on this thread for their useful contributions.
Since the sound pressure level inside my car is so great and I don't have the ski hatch access, I'm very tempted to removal the plate behind the car's rear armrests in a Tetley attempt at letting the flavour flood out... I'd be interested to know if this has been attempted before?
