Old 22nd November 2014, 07:12 PM
See Goran (and all you non-believers!). A 3.7 litre engine also helps your front end weight reduction program!!
Old 22nd November 2014, 07:21 PM
In what way? It's the same engine, what you save in pistons being smaller you gain in cylinder walls being thicker.
Old 22nd November 2014, 07:33 PM
Well that ruined that joke #tooserious!
Old 22nd November 2014, 08:08 PM
SilverS8 SilverS8 is offline
Finally got the actually weight of the Car..
1 Pcs FL S8 with half a tank of fuel and 2 babyseats
Total weight without driver 1860 kgs
Front axel weight : 1080 kgs
Rear axle weight. 780 kgs.
Mid-mounted engine seems the way to go
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 22nd November 2014, 08:43 PM
Next thing you will be telling that you can reduce weight of 3.7 by having less fuel in the tank because of lower fuel consumption
Old 23rd November 2014, 12:14 AM
Good point! And very true, also I'm sure the gearbox is lighter in a 3.7 as it's not the standard 5hp24 box!
Old 23rd November 2014, 06:48 AM
B@fink B@fink is offline
Ahem......V6.......much lighter.......less to accelerate, better weight distribution, better efficiency. Starting point is 200hp but better 'saust, better inlet, remap, 4 shiny high lift cams and you'll be not far off the 4.2. Add to that the additional weight saving mentioned and the overweight V8 trying to accelerate the extra mass and hold a line through corners on a race track will be a sitting duck. As Mr Chapman said......simplify and reduce weight!
PF late '97 D2 2.8 Aluminium Silver. Solar roof, Full Heated Leather, Double Glazing, 17" wheels, Sports Steering Wheel, Cruise, Blinds, Bose sound.
Fiat Tipo diseasel econobox with all the buttons and none of the soul that now does all the heavy lifting.
Ford Capri Laser: noisy, slow, thirsty, bouncy, no buttons but it always sounds like it’s REALLY trying and I can’t help but chuckle when it parps and boings along. And people of a certain age stare at it with a wistful look in their eyes that clearly says…I had one of them. And I sold it because of the kids
Old 23rd November 2014, 07:44 AM
From what I have heard V6 is heavier because block is cast iron not aluminium like in V8.
Old 23rd November 2014, 10:30 AM
Ainarssems is right. If you are thinking of the B5 S4 2.7 V6 Turbo, or the other similar Audi/VW V6 turbo 2.4 and 2.8, they are all heavier than the 4.2 engine.
Check out audisrs.co.uk, loads of info about that engine on there.
On the plus side though, with that engine you can mod it to over 600hp and over 600lbft.
Old 23rd November 2014, 12:42 PM
Here is a interesting one on YouTube
http://youtu.be/SmhGS4yHXxo
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
