Old 25th July 2017, 01:15 PM
Default Ventilation fan has stopped (sometimes, not always!)
Not working at all, either with ignition or driven by the solar sunroof.
Looking in the manual there's a reference to a 40A fuse but the location is not at all clear (nor if I have a spare!)
(Standard type I have spares up to 30A but is this a different type?)
The manual says "There is also a 40 amp fuse for the heater blower in the electronics/relay box under the carpet in the front right footwell. In right-hand drive models the 60 amp fuse for the radiator fan is also accommodated there".
Does this actually mean the front passenger footwell, i.e. front left on a RHD car?
If so, does anyone have a picture to show the location, or is it obvious once I dive in? (under my nice new board supplied by Sean last year )
Edit: As noted later in the thread, sometimes it works, this is not a total failure.
Last edited by HPsauce; 1st August 2017 at 09:25 AM. Reason: Improve title clarity
Old 25th July 2017, 01:42 PM
I've never had to change/check that fuse but it does seem to be in the passenger footwell, according to this pdf (position 7, S25):
Current Flow Basic equipment From model year 2001.pdf
It might be visually obvious if it's blown. Otherwise I'd pop it out and check it for continuity.
ID:	16598   Click image for larger version
Old 25th July 2017, 01:47 PM
Thanks Mark, found what I think is it mounted with a type 204 relay; looks OK, tests OK.
Old 25th July 2017, 02:02 PM
Found the same type of relay in the bottom row, left hand side (horn I think). Swapped them, no change. Not looking good.
All suggestions welcome as to what to try next. I'll do a VCDS scan but suspect that won't show anything.
Old 25th July 2017, 02:22 PM
Might just be corroded connections at the blower end.
I've never had a problem with the blower yet (touch Myrtle) so I don't know how easy it is to get to the connector (blower is just at the rear of the engine bay, is it not?). If it's easy to access I'd get a meter on the connector next ... see if you get a voltage there.
Old 25th July 2017, 02:54 PM
27litres's Avatar
27litres 27litres is offline
It's very common for the shaft sleeves of the fan to get clogged up with carbon from the brushes.
You can often get away with a clean of the centre housing.
Tapping it may give you temporary relief, or try manually ramping the fan speed up to full and see if it will go doing that.
Easy to get at fan, it's the first thing you come to under the fresh air intake grille and shut off flaps.
Good write up on Audipages for fan replacement, take the procedure as far as required...
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 25th July 2017, 02:56 PM
I've taken the mesh cover off and with the intake flaps open (they close on recirculate) I can see two connectors, one pink and one beige. Both have at least one seriously thick cable in them.
My suspicion is that one relates to the auxiliary coolant pump and the other to the blower.
Based on this rather old post by me (about my PF in 2011) I'd say the pink (purple?) one was the pump and beige one the blower:
Bonnet up this morning, turned on "rest" and it was immediately obvious where all the plumbing etc. was, just to the nearside of the air intake.
There are 2 connectors right there, a "yellowish" one to the front and a "purplish" one by the windscreen, both just held by clips.
No tools needed, took maybe 30 seconds. Disconnecting the purple one stopped the pump.
Note that on the FL model there is only one connector (beige/yellow) visible by the pump and to disconnect the pump I cut (and insulated) the relevant wires; I suspect the connector has just moved a few inches so is less obvious/accessible.
Old 25th July 2017, 02:37 PM
VCDS scan failed on the HVAC module, too many communication errors. Everything else is fine.
Controls seem to operate and I can hear flaps moving, just no fan....
Old 10th November 2017, 11:33 AM
Having recently acquired a pukka HEX-CAN USB lead (thanks Richardracer ) I finally got round to doing a scan today; this lead talks happily to all the modules.
I finally got something out of the HVAC: 01273 - Fresh Air Blower (V2) 17-10 - Control Difference - Intermittent
So, I cleared that code and will check again after a few trips; it's all working fine at present though.
The Ross-Tech wiki suggests that could be fuses, wiring, the blower or controller. No **** Sherlock!
Old 3rd August 2017, 10:36 AM
Very useful attachment which I've been studying. Thanks Mark (moltuae).
As far as I can see the main power wiring for the fan is "relatively" simple, though there are some additional thin wires to control units that are probably signalling/sensing in function.
Basically the Brown/Red Earth side goes to a major earthing point via the Blower Controller. Is that the "hedgehog" unit?
And the Red/Black Power side (up to 12v) comes via the fuse and solar panel relay.
Now, I have noticed the recirculation flaps are sometimes closed and reluctant to open, though haven't yet detected any pattern to this. Does this give any clues?
(I do normally use automatic recirculation to limit external fumes etc. but have now turned that off.)
All normal this morning though, fan ticking over gently in the weak sunlight.
