Old 13th February 2016, 03:35 PM
Here is an interesting article on HIDs VOSA vs DVA...
http://www.autoexpress.co.uk/car-new...r-mot-failures
Old 13th February 2016, 05:06 PM
Snap, Thanks. That is what I was on about.
I wish my memory still worked like you youngsters does.
Old 13th February 2016, 06:59 PM
It may be the car was IVAd and isn't Euro type approved, so might explain why it wouldn't be equipped with auto level. Only a couple of models were TAd without levelling - think a 911 variant was one - but it's in the lighting regs for UN-ECE and TA that they require both and that's been the case back to year dot of HID introduction in the late 90s. Hence my 2002 FE and all other D2s with factory HID have both fitted way before 2004 when that Evo was built
Old 13th February 2016, 09:49 PM
My 1998 PF S8 had HID's and washers and auto-levelling.
Old 26th February 2016, 12:51 PM
christer christer is offline
I changed headlight bulbs on my 4.2 V8 FSI yesterday. The offside can be changed in situ, the driver's side required moving the airbox a little out of the way. My garage charged me £16 for the work, I don't have the tools to do it myself, and for that price it did look a bit fiddly even if I had them
Audi however do quote a fortune however, not sure what they use the time on.....
Obviously the V10 may be different, I haven't seen one under the bonnet.....
C
Old 4th September 2017, 04:12 PM
lackovicj lackovicj is offline
Default Easy way to replace headlight bulb
Remove 4 screws which holds the front wheel arch linner,,,shift the linner on side (no need to remove it) remove headlight back cover, remove bulb put the new one in.. job is done In in less than 30min for both sides.
