Go Back   A8 Parts Forum > A8 D4 > D4 - Interior Electrics
D4 - Interior Electrics Airbags, Sensors, climate modules, instrument clusters, switches etc
Old 26th July 2019, 12:18 AM
neeldub neeldub is offline
Default VCDS coding needed from a fully loaded D4.
Hey guys, i'm after a VCDS coding from a facelifted 4H D4 (2014 and above) for a vehicle which has the following options fitted to it as i want to check the coding to enable those features on my D4.
- Adaptive cruise control
- Active Lane Assist
- Traffic Sign Recognition
- Side Assist
If anyone can kindly help out..many thanks
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 26th July 2019, 07:26 AM
sarg sarg is offline
Don’t those options need the appropriate hardware, surely not just a case of coding?
2019 BMW M5 (my daily driver)
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 26th July 2019, 09:07 AM
I think Ray may be your man there for that coding, I'm sure his new D4 A8L FL has most of that. Wouldnt the coding be evident from the options on each section though?
Old 26th July 2019, 09:23 AM
After extensive research on ETKA i have concluded that my vehicle has the appropriate hardware installed as mine already has adaptive cruise control from factory.
So i just want to try the coding from a factory enabled car with all those options just so i can check whether i missed anything while attempting to code myself with VCDS.
Unfortunately i cannot find anything on Elsawin, wiring diagrams or technical instructions, in regards to the features i am trying to enable, hence i have concluded it's more of a software feature than hardware.
Previously:
Currently:
Old 26th July 2019, 09:35 AM
Will this help?
File Type: txt Log-N5HNP-WAUZZZ4H3FN010516-88756km-55150mi-2.txt (30.0 KB, 786 views)
Old 26th July 2019, 10:24 AM
I followed the following coding guide from an A6 C7 which successfully enabled Active lane Assist.
https://forums.ross-tech.com/showthr...-Retrofit-DONE
Now the A6 and A8 share the same hardware in regards to the Electronmechanical steering, Onboard camera and image processing unit.
Having enabled the coding on my vehicle, the Active lane assist did work, however there were many errors on the 5F control unit and instrument cluster about missing messages and the Active Lane Icon on the dashboard would constantly flash indicating an error somewhere.
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4H0 920 950 R HW: 4H0 920 950 R
Component: TDieGBACC---- H53 0707
Revision: 37081202 Serial number: 658171014592036
Coding: 338F08001F412600010000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_RBD4K 004050
ROD: EV_RBD4K.rod
VCID: 377AA14F8E3774F22C-8062
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 Q HW: 4H0 919 204 Q
Component: Analoguhr D4 H05 0225
Serial number: 2141112000391
1 Fault Found:
16776980 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 8
Mileage: 63474 km
Date: 2019.03.20
Time: 19:14:49
Previously:
Currently:
Old 26th July 2019, 10:25 AM
Will this help?
Many thanks.. i shall have a look
What year is this vehicle built please?
Previously:
Currently:
Old 26th July 2019, 10:29 AM
Just off for a drive to Tywyn for the Tall-y-Llyn railway.
Old 27th July 2019, 01:58 AM
2014
Many thanks for the coding. Can you confirm if the coding you sent are the factory ones or have you conducted some VCDS tweaks?
Does the steering wheel actually vibrate when you go across the white lines while active lane assist is on?
Thank you
Previously:
Currently:
Old 27th July 2019, 11:23 AM
A friendly bloke with deep knowledge of 8's tweaked a few things on the day of purchase. Personally, I have no idea of the details.
Everything was updated at that time.
Everybody says that it vibrates, but my opinion is that it fights you to prevent you doing what it thinks is wrong.
