Old 18th March 2023, 01:19 PM
That first link is incorrect. GDB1523, not 1532.
It looks like the TRW fronts are no longer available in the UK, along with everything else. I only found a couple of listings on ebay from sellers which are not to be trusted (Bonum ltd and OE_quality_parts - both scammers) so it looks like Autodoc is probably the best source:
https://www.autodoc.co.uk/trw/2192146
Old 18th March 2023, 01:34 PM
I've just done the rear calipers/discs and pads. I ordered everything from Autodoc - Maxgear calipers, TRW discs and Brembo pads. The only issue was that fact that it takes a week to get the stuff - 2 weeks for the calipers as Autodoc apologised for "delays in processing".
Old 18th March 2023, 04:01 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Doh! Nice spot MJ - Thanks.
Thank you as well David. I wish I’d heard of Autodoc before. They’re quite a bit cheaper than EBay but I’ve already bought the discs…..never mind. I just downloaded the App for further discounts.
So I bought Febi discs from EBay. Are they any better or worse than TRW?
Which pads should I get from Autodoc; TRW, Febi or Brembo?
2016 S5 Coupe Black Edition - Ibis White
Old 18th March 2023, 04:10 PM
RICKY D's Avatar
Ok, maybe it’s not as straight forward as I thought
When I select Brembo pads there are multiple types to chose from even though I supplied my car reg.
I think the fronts are P85053. I’m sure I bought these for my very first s8 and the code/picture looks familiar.
The rears I have no idea
Old 18th March 2023, 04:33 PM
If you've not bought your pads and disks yesy investigate Black Diamond Disks and their Predetor pads. I have a set of these for the FL. I've not put them to a test on the track yet but I've heard good reports on them.
Old 18th March 2023, 05:16 PM
Brembo pads don't actually fit the Brembo calipers in my experience - thats why I use TRW. They're the only ones I've found that actually fit without filing down.
Febi discs are fine. Can't get TRW discs here.
I have Black Diamond Predator pads in the S8. They survived a day at Spa without complaint, although are pretty aggressive on the discs.
Old 18th March 2023, 06:10 PM
RICKY D's Avatar
Now you mention it I remember the guy who fitted Brembo pads saying he had to file them down so they could fit. Only the fronts were an issue from memory. The rears fitted without issue.
I think I will play it safe and get the TRW ones. The predators sound good but a bit much for what I need.
Old 19th March 2023, 08:17 AM
You can never have too much braking power! It's like saying I'll have the smallest parachute for my weight!
Old 19th March 2023, 09:44 AM
RICKY D's Avatar
When you word it like that Mike, it certainly makes more sense
Maybe if I don’t get on with the TRW’s I’ll slap a set of those on
Old 19th March 2023, 10:11 AM
Question
Well, I would invest in tyres first, does not matter how good your brakes are if tyres don't grip.
