Old 30th October 2014, 10:09 AM
Fine wire wool and autosol
As above, but I use first WD40 which is designed to clean chrome as well, it says it on the tin, and then Autosol, very easy job and it takes no more than 5min per side.
Old 30th October 2014, 10:13 AM
Milltek recommend silvo wadding tarnish guard - Ebay Linky
Old 30th October 2014, 10:21 AM
I'm thinking of trying Brasso! Though we do have Silvo as well.
Old 30th October 2014, 10:49 AM
This is what I have done five minutes ago, this is a quick fix.
Depends how bad are your tips, it may require more time with the polish
Before
After WD40, then apply autosol
They I fold the cloth like that and wrap it around the tip. Left hand on left side, right hand on right side and then pulling each end down in sequence left right left right for the quickest result.
Done
ID:	9384   Click image for larger version
ID:	9385   Click image for larger version
ID:	9386   Click image for larger version
ID:	9387   Click image for larger version
ID:	9388   Click image for larger version
Old 30th October 2014, 10:53 AM
Good result, but as D2 S8 tips are joined (more a figure of 8 or infinity symbol for purists) you can't wrap a cloth round, so a bit of a PITA as it's at the join it's worst.
Mine are MUCH worse than that, so I've had a little test and fine wire wool is shifting the baked on black crud.
After that Brasso followed by Silvo seems to bring up a good sheen.
Just need to wait for the dampness to dissipate and I'll attack it more seriously.
Old 30th October 2014, 11:44 AM
Conquistador's Avatar
Yeah, very fine wire wool seems to work well.
http://www.youtube.com/watch?v=O5-pAvgmJuw
Have a watch of that
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 30th October 2014, 12:20 PM
Another couple of products I've used before are toothpaste and bathroom cleaner (the mildly abrasive cream type).
In fact (inspired by Dremel comments in another thread) I'm off to investigate how an electric toothbrush with either of the above works in the awkward corners.....
Old 30th October 2014, 01:17 PM
The only thing that really worked on the tough bits was wire wool soaked in abrasive bathroom cleaner.
After that I cleaned up and finished off with Brasso and Silvo.
Interesting to look at the D2 S8 tips close up though, they're fairly obviously "hand crafted" with the brazing and grinding marks more obvious on the underside.
Given the minor surface imperfections I decided that, apart from aggressive chemical treatment followed by heavy grinding and polishing, an unblemished finish would be impossible.
Looks a lot better nonetheless.
Old 30th October 2014, 01:25 PM
I used Autosol on a dremmel polishing head - with the rear bumper removed for better access
Old 30th October 2014, 01:26 PM
Not the best photos, but at least you can see the shine. And the odd black bit inside.
ID:	9390   Click image for larger version
