Old 29th March 2013, 10:33 AM
I thought the basic point of a pressure washer was to use much less water but delivered at much higher velocity, certainly compared to a hosepipe and spray nozzle.
Old 29th March 2013, 01:28 PM
http://en.wikipedia.org/wiki/Pressure_washer
"Similarly as a garden hose nozzle is used to increase the velocity of the liquid, a pressure washer adds its own power to create high pressure and velocity. The pump cannot draw more water from the pipe to which the washer is connected than that source can provide. Moreover, the water supply must be adequate for a given machine connected to it, as water starvation leads to cavitation damage of the pump elements."
"The performance of pressure washer, that is it's total power available for cleaning is a combination of 1. pressure AND 2. flow.
A boy cycling along at 15mph hits a wall.
Apart from a few cuts and bruises to the poor lad, little damage is done to the wall.
A bus driving into that same wall at 15mph will knock it down. - Why?
... Because the weight of the object is just as important as it's speed.
So similarly, the total cleaning power of a pressure washer is a result of it's pressure and flow."
Old 29th March 2013, 02:35 PM
Thank you master Sergey now everyone. . . wax on, wax off
Old 29th March 2013, 03:06 PM
Wikipedia !
Old 2nd April 2013, 08:09 AM
Wikipedia !
No, Mr Miyagi
Old 3rd April 2013, 07:05 AM
The_Laird The_Laird is online now
Thanks for the help with this guys.
I finally bought this: http://www.ebay.co.uk/itm/2711711599...84.m1423.l2649
with a 'best offer' of £100.
I'll try the attachments that come with it before splashing out on a dedicated snow foam attachment
Old 3rd April 2013, 07:35 AM
I've got that bottle (came free with mine too) - you will want one that you can adjust flow on if you're using snow foam
Worth getting the car washing nozzle too, as it's much less aggressive on the paintwork - they're not expensive
Old 3rd April 2013, 08:05 AM
Is this the nozzle?
http://www.ebay.co.uk/itm/NILFISK-CL...item2329044c25
Old 3rd April 2013, 11:34 AM
That's the right nozzle pictured although not sure the description matches the product!
Old 3rd April 2013, 11:51 AM
That's what I thought!
But it's much cheaper than the others on ebay. I think I'll get it and complain if it's not what's pictured
