Old 25th November 2018, 04:22 PM
Originally Posted by hunker7 View Post
Also found dry joint on rear centre interior light so that now comes on when car is unlocked.
I recall playing around with mine (and a spare) for ages, on and off, with various results, assuming it was a bad contact on those "bus bars" until I decided to look at the switch unit and quickly resolder it.
You're knocking off these little problems one by one.
Old 25th November 2018, 04:28 PM
hunker7 hunker7 is offline
It's great when fixes are free. I know I've had few issues on my C4 and all it was was dry joints in relays and pumps.
Ordered spare alarm horn, seems to have the same plug but isn't D2 one hopefully it works.
Next one up is chasing down clicking noise behind centre console
Old 25th November 2018, 04:45 PM
It might not.
There are multiple versions with the same plug and two fundamental changes:
1. Different pins are used for different purposes. (You find that out after it doesn't work and you open it up)
2. The security protocol signals are different. (You find that out after opening it up and rejigging the wiring, still doesn't work!)
I think there are "some" versions from other Audi cars that will work, but most won't.
Is your original alarm horn the "rounded cube" style or the later more brick-shaped one with a circular sounder face?
Old 25th November 2018, 05:14 PM
It might not.
Part number was 8L0951605A instead of 8L0951605. So assumed it's just the 'case's that changes.
Mine is rounded cube one.
Old 25th November 2018, 05:24 PM
Can't be 100% sure but I think that's the compatible one that I now have.
The internals have changed as much as the case, different batteries as well, but hopefully OK.
Old 25th November 2018, 05:31 PM
Would it be worth opening it up, replacing batteries before fitting? Just to future proof it?
Old 25th November 2018, 09:31 PM
That's what I replaced mine with, which I got from an '04 A4, which is supposed to be more reliable. The batteries are the weak point.
I think a few on here have done that, but the two halves of the unit are pretty well stuck together. Having hacked my broken one apart (for curiosity), you need to cut through about 5mm of plastic all the way around the joint.
Old 26th November 2018, 05:59 AM
I'd prefer to change the batteries but only if I can put it back together
Old 26th November 2018, 07:33 AM
I think I came to the same conclusion as Sean, leave well alone on the later version.
Mine does throw a low-voltage error in VCDS but works fine at present.
The older model also needs cutting open to replace the batteries but has a thinner shell; I opened mine and replaced the batteries but that only lasted for a while.
I did have a "wrong" newer model and tried to open it up out of curiosity, that was pretty difficult.
Another minor point to note is that the later model siren uses a different mounting bolt. I luckily had a suitable one in my "collection".
I actually mounted it in a slightly different and more accessible position using a convenient spare hole. This was only inches away, the wiring loom has very little slack in it.
Old 29th November 2018, 06:02 PM
Got my replacement horn and no luck any ideas?
