Old 13th January 2019, 08:32 AM
hunker7 hunker7 is offline
Default Wind noise
Hi guys, me again. Just trying to sort a let down D2 I'm getting quite loud wind noise? My first thought is window frame needs adjusting but then I don't know what's the correct position? Maybe someones got untouched low miler and could post some pictures?
I have all door cards sorted with new clips and seals as it should have.
Thanks guys
Old 13th January 2019, 10:02 AM
The ideal position for the window frame is with the rubber surround just touching the door frame so it makes a seal but isn't jammed up against it. I've noticed its quite common for the top corner of the seal to drop slightly - presumably because the rubber has shrunk over time. This leaves a few mm gap at the top which can cause a bit of wind noise. I've not investigating fixing it yet but I think it'll need the whole window frame removing and the seal repositioning.
There are also rubber seals on the leading edge of the door skins to seal off turbulent air. You can get a bit of noise if one of those is missing.
Old 13th January 2019, 10:46 AM
I adjusted mine (NSR) recently after replacing the frame, it's only 4 bolts to loosen that hold the whole frame in place.
I just made sure that the seal was joined up and smooth on the outside and it was all good.
Old 13th January 2019, 12:47 PM
Nognar Nognar is offline
As others have said look at the adjustment.
Also I can highly recommend using some Gummi PFlege on the seals to puff them up a little and brings them back to life a touch.
2001 Audi A2 1.4 SE - Jaipur Red Pearl
2002 Audi D2 4.2 S8 - Ming Blue Pearl
2002 Audi D2 2.8 A8 QS - Audi Silver
Old 14th January 2019, 07:09 PM
Thanks guys for info. Part of me thinks it is sunroof and not doors, but it's hard to tell. Does sunroof adjust with little Allen key like most cars?
Old 14th January 2019, 07:39 PM
Never tried it tbh. Does it sit flush with the roof?
Old 14th January 2019, 08:00 PM
Maybe slightly above roof? I'll take some pictures tomorrow
Old 27th June 2019, 10:25 AM
Ok, been working my way through adjusting doors to sit nice and flush and that's definitely improved things. Tried doing sunroof but only have access to back bolts, does it really need taking apart to get access? Had bad experience re' sunroofs so I'm a bit cautious.
