Old 17th May 2019, 08:14 PM
Default S8 D3 BSM Vacuum system
Hi folks,
Can someone point me in the direction of a circuit / layout of the vacuum pipes on the 5.2 D3 S8?
I can trace these lines easily enough under the hood to secondary air control and the air valves on either air filter housing all originating from the inlet manifold however, vacuum hoses disappear into the wheel arch going somewhere else. What else is connected?
I’m trying to resolve a vacuum leak and when I remove the pipe from the inlet manifold and connect my manual vacuum pump into the circuit there is air getting in somewhere...
Any thoughts?
Cheers,
Present cars
Daily driver: BMW e65 730d
Old 17th May 2019, 08:20 PM
While I am not that familiar with D3 S8, there is probably vacuum accumulator in wheel arch and I think there are vacuum valves for exhaust switch over.
Old 17th May 2019, 09:10 PM
Thanks for that - I was suspecting that when the miltek exhaust was fitted the vacuum lines may be leaking/ not properly sealed off...
I was hoping to verify that vacuum lines had no other functions outside the engine bay.
Thanks,
Present cars
Old 17th May 2019, 10:17 PM
Hopefully this should help.
