Old 9th October 2014, 10:21 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Brilliant mate.
thanks for being the pioneer on this.
I fear my master switch will be a little bit more tricky cause of my rear door controls.
I'll sort something out cause I want these switches.
[center]
06 3.0TDI Quattro:
Options:
Old 10th October 2014, 08:35 AM
ScottD3's Avatar
Thanks M-A8 for sorting out my switches.
I'm getting a little more worried about my independent rear child lock buttons.
I'll sort something out I'm sure.
[center]
06 3.0TDI Quattro:
Options:
Old 10th October 2014, 10:38 AM
Oli18's Avatar
Oli18 Oli18 is offline
Top mod!
Audi A8/S8 D2 Flickr Group
Old 10th October 2014, 10:49 AM
Oli !!!!!!!
Long time no see. How's things mate and most importantly how's 8??
Scott, no problemo mate
Old 10th October 2014, 08:57 PM
ScottD3's Avatar
The joys of half day Fridays mean I can add these switches to my 8.
Heres mine.
Sadly the master switch from 8P lacks the individual child locks like the 8 and they are so massively different I can't swap bits overseas. With 8P unit in it the child locks and window locks still works.
I'm working on a different master switch so I can keep the individual switches.
[center]
06 3.0TDI Quattro:
Options:
Old 10th October 2014, 10:26 PM
Cant the button caps be fitted to the existing switch unit to keep the individual rear lockouts. My car is like yours so I am watching with anticipation.
Old 11th October 2014, 03:54 AM
Del, rest assured that this will be done.
We found a pretty good solution withoit modifying too much (caps swap)
Caps can't be swapped, they're so much different it's almost impossible without employing an engineering team
Everything will be fine Del, few more sleeps and Scott will have it done
Old 14th October 2014, 08:20 PM
ScottD3's Avatar
The A6 switch turned up today.
It looks identical to the 8P unit but with the different chrome and dead lock buttons.
Under the caps is identical as well.
Stripped the door card down again, removed the master switch and swapped the caps over.
The A6 dead lock buttons are slightly different shape but they look fine and works.
I think thats the switches completed.
I now got all these switches left over.
ID:	9288   Click image for larger version
ID:	9289   Click image for larger version
[center]
06 3.0TDI Quattro:
Options:
Old 15th October 2014, 06:37 AM
So, to close this thread here is the solution for anyone having individual child locks on the master switch.
You will need a Master Switch PN: 4G0 959 851 instead of PN: 4F0 959 851 H
...and do what Scott did (as above), swap the window switches caps
That's it !!!
Mod COMPLETED
Old 15th October 2014, 09:27 AM
ScottD3's Avatar
That it is.
Bring on the next installment of chrome mods.
Thanks again for you help with this mate.
[center]
06 3.0TDI Quattro:
Options:
