View Poll Results: I have the following Calliper/Disk combination
RS4 front calliper and disk 0 0%
RS6 front calliper and disk 0 0%
AP Racing calliper and disk 1 3.13%
Brembo front calliper and disk 8 25.00%
standard front calliper and disk 17 53.13%
Standard front calliper with EBC disk 2 6.25%
Standard front calliper with black diamond disk 0 0%
Other calliper with standard disk (post below) 0 0%
Other calliper with upgrade disk (post below) 1 3.13%
I use an anchor 3 9.38%
Voters: 32. You may not vote on this poll
Old 10th July 2009, 09:20 PM
I'll point him this way!
Old 11th July 2009, 06:31 AM
CliveH's Avatar
CliveH CliveH is offline
Default Is the D3 setup a viable option?
Just wondering... (rears too?)
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs
Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten
Old 11th July 2009, 06:58 AM
A quick bit of research shows that the 2004 and 2007 models have a greater range of options from 323mm disk with single pot sliding callipers; via 360mm disks with twin pot sliding callipers up to a mahosive 385mm with twin pot sliding callipers.
8 pot callipers don't seem to appear until you get onto the 380mm ceramic disks.
Rears start at 280mm with single pot sliding callipers and work up through 310mm, 335mm to the 356mm ceramic. The one thing to note with the D3s is that they have an electromechanical parking brake.
The hub carriers are fundamentally the same design as the D2 so there may well be some transplant options.
Old 11th July 2009, 09:47 AM
Also watch out for D3 brakes as the Adaptive Cruise uses different calipers too I think (due to the automated activation of the brakes).
Old 12th July 2009, 01:21 AM
ChriS8 ChriS8 is offline
Hi there.
A quick translation of this:
1 Set of Audi RS6 Brake calipers incl. assembly material.
It's original NEW Audi-parts.
These calipers are in the Audi RS6 using 365mmx34mm discs.
We can also submit adapters for using the 385mmx36mm discs on these calipers.
These calipers can be used at almost every car, assuming the right adapters.
It's about the 8 pot calipers.
We also offer a full reconstruction kit for Audi RS4, A8, S4 and others (watch the shop).
The parts certainly can be assembled to your car in our garage.
Shipping within GE is 10 €, to other countries we are looking for a cheap shipping to you. Request by indicating your adress.
Further information call: 00499931/6066 or mobile: 00491754641206 or mail adress audi@urquattro.net.
Now playing: Jennifer Rostock - Gedanken, die man besser nicht denkt
via FoxyTunes
Now playing: Jennifer Rostock - Tier in dir
via FoxyTunes
Audi S8 manual, 1996 <- much fun
Kawasaki ZX9-R 2001 <- much more fun
always remember:ficken!
Old 12th July 2009, 01:28 AM
A translation of this:
Selling 2 brandnew original Audi / Brembo brake calipers of the RS6.
Colour black with a print of "RS" on it.
8 pot.
assembled on the big disc with 365mm x 34mm.
coming with Ferodo brake pads.
ideal for converting from Audi A4/RS4
without any holders and brake discs.
Without any warranty or retraction.
Now playing: Jennifer Rostock - Mona Lisa
via FoxyTunes
Old 12th July 2009, 01:32 AM
Guys, if you need any information from the first translation (given telephone-number), I can call there and ask about everything!!! It's really no problem.
Just give me a description of your queries and I'll talk to that company there.
Greetz, Chris.
Now playing: Manowar - Thunderpick
via FoxyTunes
Old 12th July 2009, 07:24 AM
thebluewhale's Avatar
Chris,
Thanks for the translations, I think I'll be going for the set at Urquattro as I'll also need the mounting brackets.
Could you give them a call and ask for a price for the calipers and mounting brackets for a 2000 S8 (already has 4 pot brembos). Also which payments they accept as I a bit concerned that they don't accept Paypal.
If you need anymore info let me know and thanks again.
Steve
Old 12th July 2009, 12:50 PM
Sure! I'll do that tomorrow on monday
As soon as I called there, you get a post here.
Chris.
Now playing: Rammstein - Zwitter
via FoxyTunes
Old 13th July 2009, 03:19 PM
Hi.
So I had a friendly call to the Urquattro-guy.
There are several possibilities to get your A8/S8 negative accelerated
This is exclusively for the front wheels.
You can only go on 18"-Wheels or bigger.
In all offers are included:
-2 front brake discs
-brake pads
-2 brake calipers
-metal hose kit
-adapters to mount the caliper
At first there's the 365mm-disc (two section, alloy & steel, VW Phaeton disc)
Without any holes in the disc the set costs 1790 €.
With slotted discs it's at 1900 €.
With punched discs the set is at 2100 €.
With the cheaper 385mm-disc (one piece, full steel)
in punched design the set is at ~1750 €
Further there's the option to install the 390mm-discs from the new 4F-RS6 (seller recommends that option )
With the punched discs the set costs 2150 €.
Payment could go by Paypal, but he doesn't want paypal to earn about 40€ for one transaction. An other solution could be found in case of purchasing.
Shipping to the UK will take 52€ for the whole kit.
Mind the possibility to get a set carried by a visitor of the german A8-Freunde-meeting in August.
So far, hope I could help you.
Chris.
Now playing: Blink 182 - AudioTrack 18
via FoxyTunes
Now playing: Blink 182 - AudioTrack 04
via FoxyTunes
