Old 27th October 2020, 11:54 AM
RICKY D's Avatar
RICKY D RICKY D is offline
Default Spec boot build sticker
Does anyone know the difference between these codes?
I found something online to check codes but I'm not sure it's right. My codes from my S8 on the left vs another one I looked at a while back. Something about glass I think
Current S8 first followed by previous S8:
3L4 vs 3PN
4KP vs 4KV
4GP vs 4GM
Also what is 1N3? something about variable speed??? Mine has this but I'm not aware of the function
Rich
2016 S5 Coupe Black Edition - Ibis White
Old 27th October 2020, 01:04 PM
This is what the decoder on the PlanetVAG.com sites gives for those codes:
PRCode: 3L4 = Electric seat adjustment for both front seats driver's seat with memory system
PRCode: 3PN = Electric seat adjustment for both front seats with memory system
Assuming 3PN has passenger side memory as well
PRCode: 4KP = Side and rear windows acoustic glass
PRCode: 4KV = Side and rear windows in laminated glass
PRCode: 4GM = Laminated windshield with sunshield and viewing window for vehicle identification number heated
PRCode: 4GP = Windshield in heat-insulating glass with sunshield and viewing window for vehicle identification number
Different glass types for above four items
PRCode: 1N3 = Speed-related variable steering assist (Servotronic)
EDIT: Website is as follows: http://prsearch.planetvag.com/
Old 27th October 2020, 01:25 PM
RICKY D's Avatar
Thank you Sean.
ok, so I definitely have servotronic!
Regarding the glass, does laminated mean no double glazing then? My current S8 has acoustic glass which I assume means double glazing?
Old 27th October 2020, 02:06 PM
pete-p's Avatar
pete-p pete-p is offline
Thank you Sean.
I don't think so. I have the same code (4KV, laminated) on mine and they are double layer. Not sure what the difference is between acoustic and laminated though.
Cars...
Old 27th October 2020, 02:24 PM
RICKY D's Avatar
Ah ok, thanks Pete, and I think you're right.
http://forum.a8parts.co.uk/showthread.php?p=141697
Just looking back at this post from Dean above with the original brochure and it states that 'Twin pane heat insulating glass' is standard equipment.
And then I found 'Twin pane heat and UV light insulating glass with heated windscreen" under the options list.
So I wonder if it is this option. Does yours have a heated screen Pete?
Old 27th October 2020, 02:40 PM
pete-p's Avatar
Yes I have 4GM = Laminated windshield, with sunshield and viewing window for vehicle identification number, heated.
I've only noticed the heating work once, the windscreen demist button flashes when it's activated.
I wonder if the different codes also relate to facelift/pre-facelift.
Cars...
Old 27th October 2020, 02:52 PM
RICKY D's Avatar
I wonder if you automatically get 4KV when you get 4GM then? The other car also had 4GM listed.
I wish I knew more than I do about these
Old 27th October 2020, 02:58 PM
Only V8s have the laminated / twin pane side & rear glass (4KV) as standard, whereas it was an option on the V6 (none of my V6s have it). The UV insulating coating was definitely an extra option as not many seem to have that. You can usually spot that as the glass looks purple from outside, plus you can't get a phone signal or GPS in the car!
Not sure what the difference between laminated and acoustic is though.
Old 27th October 2020, 04:48 PM
The heated screen only works once the temperature drops below 5 degrees.
Mine has 4KV as well as 4KM (probably the only option ticked on mine).
Most definitely. Could never get a GPS signal on my mobile when I wanted to use it.
Regarding glass types, here are the three types:
PRCode: 4KC = Side and rear windows in heat-insulating glass
and like MJ, I've no idea in the differences.
Old 27th October 2020, 06:15 PM
RICKY D's Avatar
Ok that puts my theory out the window. So you could spec them separately by the sounds of it.
I’d love to know what the difference between them is now....just to satisfy my curiosity
