Old 29th October 2015, 05:17 PM
Hmmm, no part numbers visible on my bits.
The ones that look right have a central hole about 12mm dia on the underside and 11mm on the top.
Overall about 38mm diameter.
Old 29th October 2015, 06:14 PM
Norretal's Avatar
Norretal Norretal is offline
Good evening John, I'd be interested in the front pair if they're less worn than my current pair. I've just checked them and they're well worn but not split or anything. My rear pair look untouched so I've no need for them. Zooming in on your pic of the fronts doesn't really confirm they're better than mine but if all the driver one has is some heel wear I suspect they are, as mine look as if they've been in the car for nearly all of its 125,000 miles. The raised pattern on the fronts has very rounded edges compared to the rears so I'm hoping your fronts aren't showing that same level of wear, could you confirm please?
Audi TT - 2015 - Ultra
Old 29th October 2015, 08:42 PM
47p2's Avatar
47p2 47p2 is offline
There is heal wear on the drivers mat, not sure how to compare it with what you have, these were used for 60,000 miles before I bought the car and I took them out then and they have been in the garage attic since.
Nite Blue 3.0L SE Quattro
Old 30th October 2015, 11:22 AM
Norretal's Avatar
Thanks for that, I appreciate your honesty in not describing them as nearly new or barely used. I'd say at 60k miles they'll be half as worn as mine as I put tailored mats in at 120k miles and carpet condition suggests they've been in since new.
I'll take a close look at mine again tonight and compare them with you photo and decide if I can justify the outlay. I'll be back when I've made a decision, thanks again
Old 30th October 2015, 06:17 PM
I've still got these spare carpet/mat fixing clips sitting here if anyone wants to send me a photo of the existing ones that are correct...........
