VCDS Faults
Did a VCDS scan and apart from the normal handles and rear footwell faults I had some new ones that won't clear.
Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 A HW: 4E0 815 069 F Component: Heizgeraet H07 0110 Revision: 0000000C Serial number: 00000009006406 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 1A3C5ED0D55678FB2B1-804E 2 Faults Found: 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication ---------------------------------------------------------------------------------- The Aux heater works as far as I can tell. Turn it on via HVAC controls and it kicks in and you feel the heat coming from the exhaust. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 R HW: 4E0 035 223 G Component: DSP-High D3 H02 0120 Revision: PROD_01 Serial number: 00000000200813 Coding: 0000003 Shop #: WSC 02313 785 00200 VCID: 2C5088088FC2F64B49D-8078 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 76 Mileage: 283835 km Time Indication: 0 Date: 2016.08.03 Time: 16:03:45 As far as I can see its coded correctly. Right hand drive, with leather and a diesel. Plus 1 for the microphone. It was set to 03 and I added the 1, reset and rescan. same fault code. If anyone got any ideas, that wold be great. I'll have a better look this weekend.
The auxillary heater code ......... has the extra water pump been fitted on the thermo top aux heater .
Can you set the timers so it comes on in a morning ? I did the aux heater mod on mine so i can have them on the timer, and i have that code..... the company data bus one . It works fine so i never really looked into it but i think its just the level of communication not quite in sync between the modules . |
I got everything I need (I think), apart from the pump cables. Just not got round to it yet. Could be that then.
