Old 6th March 2012, 02:41 PM
Glync's Avatar
Glync Glync is offline
Default Wheel advice
Hi All
My 8 is now due a set of tyres and before I change them I need to sort out my wheels. When I last had them balanced the tyre chap told me the spare and one of the rears was slightly out of shape . Although you would never know this from driving the car, no vibration from the rear). I assume pothole damage before I bought the car! So question is... can this be repaired or is it scrap? There are a couple of firms stating they can fix this in the web, has anyone had this done?
alternatively, I have been watching the auction sites for a second hand one to replace the rear but they only seem to come up for the RS6 which I believe is a different offset. My wheels are the five spoke sport type and in good condition visually anyway! I did consider after market wheels and changing them all but it seems extreme and costly and some of the quality is questionable if you don't part with a lot of cash. So any pointers or firms that might be worth a try to get at least one straightened: in and around the Midlands would be appreciated I can always leave one with them to get this done.
On the tyre front I have been offered a cracking deal on some Bridgestones through a contact of a friend. 225/40/19 Potenza S001's anyone had experience of these??
I have previously had the standard fit Dunlop Sports which had been ok but seem to wear quick and I have been warned they have a tendancy to go out of shape (Audi dealer mentioned this at the last service)! Also would like to try a non directional tyre so I can swap them around more to even out the wear I don't know if the Bridgestone are but need to check this out!
Any input appreciated
Glyn
Old 6th March 2012, 05:45 PM
47p2's Avatar
47p2 47p2 is offline
Be very careful if you go for aftermarket wheels, some are not strong enough to take the weight of the car
Nite Blue 3.0L SE Quattro
Old 6th March 2012, 06:06 PM
Glync's Avatar
Thanks mate
That's what I had decided tbh I have seen some very poor castings and it would worry me to know I had them on the car. Having said that the Audi wheels are so damn expensive to replace.
I just need one decent rim to replace mine but they appear to be on the rare side of rocking horse doings for the 8
Old 6th March 2012, 06:10 PM
47p2's Avatar
There are companies who can repair alloy wheels, anything from bashed rims to cracks
Old 6th March 2012, 08:03 PM
Lepsons will normally have a go at repairing as long as its not unsafe to do so
www.lepsons.co.uk
Old 6th March 2012, 09:35 PM
225/40/19 is quite a bit out from what you should be running (255/35/19), so your speedo will read wrong and handling will be down a little.
Old 6th March 2012, 09:53 PM
225/40/19 is quite a bit out from what you should be running (255/35/19).
According to my maths these are virtually identical.....
(0.3% different according to my tyre/wheel size calculator)
Old 6th March 2012, 09:56 PM
Erm... so it would
Though, still 30mm narrower than it should be, might not make much of a difference normally, but you never know.
Old 6th March 2012, 10:03 PM
Depends on the rim width, which I don't know, but you may.
225's would normally fit on anything from 7" to 8.5".
Remember that 225mm is less than 9" so would be very doubtful on 9" rims...
Old 6th March 2012, 10:20 PM
Glync's Avatar
Sorry chaps that was a Typo from me blinking iPad and fat fingers it's causing me so much trouble on emails
Tyres are standard for my motor at 255/40/19 currently Dunlop sports sp9000
Anyone running bridgestones on their 8 I have these on offer for around 160 a go and from what I have seen online there normally near 250
Will get on the phone tomorrow re possibly getting the wheels straightened out as I would prefer to keep them stock
