Old 27th November 2012, 10:57 AM
Conquistador's Avatar
Question Front LED indicator bulbs
Would it be possible to change my standard front indicator bulbs for LED bulbs? Or would the car scream at me saying it has an error? They are 581 bulbs if I'm not mistaken.
Something like these...
http://www.autobulbsdirect.co.uk/581...1125&end=front
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 27th November 2012, 11:00 AM
Why bother, what do you want to achieve?
Old 27th November 2012, 11:05 AM
Well, just a nicer looking light at the front I guess. OCD!
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 27th November 2012, 11:10 AM
sloss's Avatar
sloss sloss is offline
LEDs give a much crisper on/off but you would have to put resistors in parallel so you need somewhere to place them where the heat won't melt any plastic etc.
Old 27th November 2012, 11:16 AM
Hmm, I don't see how an orange LED looks nicer than an orange bulb when it's on. Which isn't often anyway, but it has to be orange. Still perplexed....
If you have an orange bulb or lens showing when not operating and don't like that then there are simple solutions.
Both my cars have silvered/chromed bulbs under clear lenses in the front indicators and side repeaters. They look clear but flash the correct orange colour. Cheap as chips too.
Old 27th November 2012, 11:38 AM
I think some of the "chromed" look bulbs look brighter and more LED-ey than normal bulbs but without any of the hassle / risk. I changed mine when I was up at A8 parts and think that they look better both when flashing and even when they arent lit! They look a sort of purpley colour when they are not lit.
I'll try and take some video if the sky ever gets bright enough here and post . . .
Old 27th November 2012, 11:43 AM
The main front indicators in my S8 are somewhat like that, but you have to look pretty carefully through the multi-faceted lens to notice.
There are many variations though and the main ones I have in the Focus have a very chrome look when unlit (lens is clear).
Old 27th November 2012, 11:45 AM
Yeah I had the chromed bulbs on my last car to avoid the 'fried egg' look, that will probably be the route to take rather than sodding around with resistors etc.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 27th November 2012, 12:03 PM
Here you can see my clear Focus indicator (faceted reflector) with chromed bulb and faceted S8 one with blue-tinged indicator bulb.
ID:	5323   Click image for larger version
Old 27th November 2012, 02:19 PM
Our bulbs are not the ones in the OP, they are py24w.
They are super expensive in tungsten and even moreseo as LED, and you need 4, so think about $120. The alternative would be to brew your own using your existing bulb base and some 1156 or1157 SMD luminaires from dx.com or ebay.
