Old 5th April 2018, 11:21 AM
ulfilias ulfilias is offline
Default MOT Fail - Emissions - Probably Cats
Hi There,
4.2 V8 Petrol ~162,000M
Just had an MOT.....Failed Emissions on CO on Idle, 2nd fast Idle, Fast idle and HC/Lamda on the fast Idle.
The Co points to the cats. I've had the Check Engine lights on for quite a while on both banks which I thought was odd (16814 & 16804)....I did try a few cleaners when I got the car, but since it's passed the two years previous MOTs I haven't been worried.
I've got some toluene so I may give that a go and see if it gets better, but I'm guessing it's a pair of new cats ???
Any help, pointers etc
Lee
Current :
Previous :
Also :
Old 5th April 2018, 12:16 PM
If the lambda probes are not too expensive I would just replace those as it failed on fast idle lambda value / mixture.
Old 5th April 2018, 01:34 PM
Just had a play with VCDS
I'd cleared the error code before the MOT, but i just did a readiness test and it passed everything apart from the Cats, so 0000 0001
It seemed to think the sensors with the aging test was ok
Blocks 46 and 47 read Cat 0.13 and 0.19
I've got some Toluene and half a tank of gas, so i'll go for a drive and see if I get any real change.
I had a cat issue with an Rx8 I have and on swapping, found the housing empty....Am wondering with an inspection camera if you could feed it down the exhaust or maybe break the pipe and do a visual inspection???
Current :
Previous :
Also :
Old 5th April 2018, 01:40 PM
I agree as it failed lambda as well it's more likely to be first lambda sensors or possibly air leak. Have a look at values for lambda voltage in measuring blocks with VCDS. They should be changing quite sharply between approximately 0.2-0.7V about once per second. If there is no activity, smaller range or slow to respond then it/they are faulty. But if you keep driving with faulty lambdas for long time that will eventually damage cats.
Old 10th April 2018, 03:23 PM
Looking at the MOT they'd tested it on Petrol. Retest on LPG and that's the MOT sorted.
However the LPG runs rough and having been through the system, plugs and coil packs, I have a feeling the sensors may be having an effect there, so i'm going to have to do some investigation there, but at least it's not the CATs. Workshop guide for the garage was say 12.5hrs for a cat and 13hrs for them both!!!
Current :
Previous :
Also :
Old 10th April 2018, 07:49 PM
Can you post all gas readings off print out
Are pre cat Lamdas 5 wire wide band ?
What is short term fuel trim doing at idle and at say 2500 rpms
Old 11th April 2018, 12:10 PM
Mechcanico Lee
Bit confused on what you want, but happy to play!
I can hook up VCDS this afternoon and look the fuel trims, LPG or Petrol?
CO is fine on LPG, though HC is high, but just within the *MUCH* wider limits than on petrol and only until the LPG drops cylinder 8 though it also mentions 10??? It's only a V8
I think what is happening is that the post cat sensors being out is meaning that it's either under or over fueling causing the emissions issues and the LPG is trying to trim to such an extent the miss fires are happening!
Current :
Previous :
Also :
Old 11th April 2018, 12:39 PM
Post cat lambdas is only there to monitor cats, they do not affect fuelling.
All lambdas are narrow band on D2.
Old 11th April 2018, 01:41 PM
ainarssems - It's a D3!
Current :
Previous :
Also :
