Old 18th November 2018, 10:45 PM
Versace Versace is offline
Default Bose retrofit
I have almost all options on my 02' A8 and one of the missing options is the Bose audio system. I've had it in my previous A8 and i'm missing it most of everything ever in a car!
I know that the retrofit IS possible but I want to know if I have to install all new cables or do I just connect new speakers and the amp with the headunit?
S8 D3 FL II.
Porsche Cayenne 958 Turbo
BMW E83 X3 3.0d M-Sport
Old 19th November 2018, 07:55 AM
You have to replace the whole harness, from the boot up to the head unit, as the Bose system has larger speaker wires and low-level outputs for the amp which the standard system doesn't have. All the antenna cables for nav, radio, tv etc are also in the same harness.
Seats, carpets, rear shelf and centre console out to get to it all, but its easier to do that than to try and pick apart the harness.
Old 19th November 2018, 10:57 AM
I think IT did it a long while ago and documented it too.
Pretty big job as MJ has said.
Old 19th November 2018, 04:02 PM
RICKY D's Avatar
RICKY D RICKY D is offline
By modern standards it’s just an average system anyway. You’re better off getting an upgraded headunit and speakers.
2016 S5 Coupe Black Edition - Ibis White
