Old 7th February 2013, 04:12 PM
Default One indicator is dimmer than the rest!
Weird this.
I bought some silvered bulbs for the front indicators, to eliminate the "fried egg" look.
After fitting them I noticed that the nearside one looked dimmer, but thought at first it was just an illusion because that side was sunlit.
Today I checked again in overcast conditions and there's a definite difference, so I took the bulbs out, checked resistance (identical) and swapped them. Still dim on the nearside.
I also made sure the sockets were clean and shiny and the bulbs well-seated. Wiring appears to be in good condition.
Only thing I didn't check was the actual voltage in the socket, it's a bit tricky.
The side repeaters and rear indicators all appear to be fine, no imbalance.
Any thoughts?
Old 13th February 2013, 09:35 AM
The indicator is getting worse, sometimes dim sometimes dead with "double-speed" flashing on that side. Made some progress today, but no solution, advice needed.
I've pretty much convinced myself (by swapping, wiggling etc.) that the problem is the contact between the plug on the end of the wiring and the bulbholder.
But I can't get the bloody thing off to investigate/clean and there's not a lot of slack or space to work in - getting grazed knuckles!
Looking at the plug there seem to be a couple of protruberances that "might" be latches of some sort, but (especially in the cold making plastics brittle) I don't want to break anything by forcing the wrong part and it's not really obvious.
Does anyone know how to detach the front indicator bulbholder from the plug safely?
Old 14th February 2013, 12:33 PM
OK, all sorted.
Turns out it was a dodgy bulbholder which "succumbed" to a bit of bending and scraping.
The bulbholders, for those that don't know, firstly come out of the headlight by rotating about 30 degrees in the socket, then the wiring connector has a funny shaped rectangular object at the wiring end that when pushed away from the bulb releases a catch. (There's what looks like another simpler catch on one side but it isn't.)
First I swapped them to discover the dimness moved with the holder - result!
Then I took them indoors and looked more closely.
One one the side contact was less firm, in fact the bulb wobbled, so I bent it to match the other. Still not great on the car though.
Looking closely (my old eyes aren't good at this) I could see that the contact area was corroded, probably from being loose and intermittent, so I scraped it down to shiny metal and combined with the firmer contact that solved it.
On to the next problem now.....
Old 14th February 2013, 01:13 PM
sloss's Avatar
sloss sloss is offline
You have more problems.....
