Old 10th June 2022, 03:31 PM
The main reason is cost. Second reason is that I just want something to play music and give me sat nav whenever I need either of them.
An Android head unit surely is cheaper than the elusive C5 RNS-e? The Icebox one which looks similar is £320 iirc. Nice condition RNS-e units seem to be 300-400 plus all the adapters and expensive 4GB non-HC SD cards.
I'd consider an RNS-e a more expensive option where you are prepared to pay for the OEM integration and user interface. The Android unit is a pain with Bose because of the odd characteristics of the amp, but non-Bose should be simple enough. I'll grant it does get more expensive and complicated when you have to change the amp though.
Old 10th June 2022, 05:02 PM
There was a second 'gala' input on the 8 way power block, which was also a speed input.
I'm pretty sure that's the one that you break for TV-in-motion and it doesn't do anything else.
I'm certain My Kufatec TVIM lead loops in there via an adapter.
Though I'm hoping (fingers crossed) that wiring can be simplified and the adapter dispensed with while my S8 is down with MJ.
(The DVB-T tuner I'm also giving up on so it's only the reversing camera that needs it. Surprising how often I reverse faster than 5mph though.... )
