Old 6th December 2019, 02:35 PM
Default Re-bush or replace?
I'm just curious as to other owners experience / opinion on Re-bushing audi suspension control arms.
I've never really felt the need to Re-bush any aluminium suspension components up until this point, I generally just replace the whole thing. As control arms are getting harder to get hold of for my D2 rear end I thought I'd give it a go.
I bought some second hand rear control arms and some Febest bushes to experiment with. I have a 6t press and variety of pressing tools to use so was expecting it to be pretty streight forward.
I couldn't have been more wrong......
I managed to get the 6 bushes out of the 2 rear control arms but it was a real pain and took ages. I have, as yet, not managed to get a new one back in without destroying it. No mater how much I clean the arms and lubricate the bushes, they always seem to jam up 3/4 or so of the way through and then the press just distorts them.
I know it can be particularly difficult pressing into aluminium as things seem to pick up on the ally but what am I doing wrong here? Or is re-bushing just generally not a good idea?
Audi S8 D2 2002 88k mls
Old 6th December 2019, 03:40 PM
I re-bush the rear arms a lot. They have to be destroyed to get them out, but then they all do. I made a tool to push them back in though - its a cup shaped thing which presses on the outside flange and the centre at the same time so it doesn't try and push the rubber through the flange. I put them in with a bench vice since I don't have a press, and always lubricate them with WD40 or similar beforehand.
Old 6th December 2019, 04:15 PM
I actually have the official VAG 3350/2 tool which I guess is similar to what you are using. I've been using it in a press rather than with the bolt and cup that it comes with. I thought the press might be easier.
One thing I have just noticed is that the Febest bushes are slightly different in that the outside diameter is slightly larger. Only 1/2 mm or so. Would that be enough to cause them to jam?
I have an original bush so I'll give that a try in the vice tomorrow. I'll let you know how I get on.
Old 6th December 2019, 04:32 PM
The original alloy bushes are larger than the hole too. You can see them necking down as they go in. The single-piece steel one isn't though obviously. Thats just a very tight interference fit.
3350/2 isn't quite what I've made - that looks like it presses on the outer flange only whereas mine is a lot shallower so it also touches the inner bushing, although doesn't put any significant force on it. Theoretically they ought to achieve the same result.
Sometimes tapping the arm with a hammer around where the bushing goes in helps to release the stiction and it jumps in a little further while still under pressure from the vice.
I've not really had any problems pushing them in tbh - getting them out is more of an ordeal, especially the steel one.
Old 8th December 2019, 10:50 AM
Sorted
Got rid of the press, used a combination of the vice and the vag tool. All went together easily with no drama at all.
I don't think my press is pushing squarely. It's only a cheap thing.
Old 8th December 2019, 11:06 AM
Good news I've never done the upper arm - there never seems to be any appreciable wear on those.
Were the bushes available from Audi or are they aftermarket?
