Go Back   A8 Parts Forum > A8 D4 > D4 - Common Faults
D4 - Common Faults Quick links to all known common faults and their solutions
Old 8th May 2016, 07:45 PM
nath nath is offline
Default d4 wiring loom issues
just noticed there is nothing whatsoever in the d4 section
for common faults ...
having read a couple of other forums im concerned about the coolant pressurisation problem which now appears to be affecting d4 vehicles
has anyone experienced this as yet ?
Old 8th May 2016, 08:15 PM
no tell more
Old 8th May 2016, 08:16 PM
Joe2.0E Joe2.0E is offline
Not sure if this is relevant but I had a coolant pump of some nature replaced under warranty last summer. My D4 is a 2011 3.0TDI with 60k miles. I wasnt aware of any issues but apparently a fault code flagged it when it was in my local Audi dealer for a software update. From memory it wasnt expensive but I'll have a look for any paperwork that might show a part number if that helps.
Old 8th May 2016, 08:50 PM
Interested in this also...... I have this logged, cleared and comes back
Code:
0378 - Coolant Circulation Pump
          B10D0 04 [009] - Internal System Fault
          Confirmed - Tested Since Memory Clear
Led me to a few threads like this http://www.audiworld.com/forums/a8-s...rness-2862459/
Due to go in under warranty in a couple of weeks
Old 8th May 2016, 09:41 PM
Could have sworn this stuff was in the common faults section like the D2 and D3 sub sections.
Anyway here it is for your reading pleasure
http://forum.a8parts.co.uk/showthread.php?t=8379
Old 8th May 2016, 10:21 PM
V059121012A is the part no. for the coolant pump replaced on my D4.
Google indicates its a small cheap looking plastic pump, no surprise it didnt last long. Not sure it does much anyway as i hadnt noticed any issue prior to replacement or any difference afterwards.
Photo attached from Garage Paperwork. Prices are in € + vat.
Old 8th May 2016, 10:32 PM
At that price not the end of the world, so long as it isn't an engine out job to fit it time wise!?
Old 8th May 2016, 10:38 PM
As it was warranty work, I never got to see the Invoice but I would say it was less than 2 hours based on the length of time they had the car.
Old 8th May 2016, 10:47 PM
Would it be cynical to think that in warranty its a "swap the pump and it will be fine" and out of warranty is where the £xxK bills come in!?
Old 8th May 2016, 11:11 PM
reading the other threads though this is the tip of the iceberg, the liquid is forced down the sleeving of the harness in to modules. then it will start to add up.
Thread Tools
Display Modes
