Old 23rd May 2016, 09:44 AM
Default Replacing the passenger side footwell relay cover
After recently bunging up my botang's, replacing my ECU box seal/cover and (hopefully) ridding myself of all other sources of water ingress, I just couldn't bring myself to refit the manky, water-damaged footwell relay cover, so I started looking at ways to replace it.
I've always felt that the choice of materials for this cover, essentially foam-backed compressed cardboard, was pretty poor, so I didn't even bother looking into replacing it with a new one. So I decided to make one ...
This was my original cover, a bit minging but in good enough shape to act as a template:
Name:	2016-05-22 15.24.52.jpg
ID:	13393Click image for larger version
Name:	2016-05-22 15.25.09.jpg
ID:	13394Click image for larger version
Name:	2016-05-22 15.26.09.jpg
After hunting around for suitable material, with ideal criteria such as inexpensive, lightweight, waterproof, insulating, fire/heat resistant and easy to cut, I settled on 10mm 'tile backer board':
http://www.ebay.co.uk/itm/221471642769
Name:	Til-backer board.JPG
This particular board was made by Nassboards:
http://www.nassboards.co.uk/Insulation-Boards-10-x-10mm
Using spray-mount adhesive, I added a thin (about 1-2mm) black foam rubber sheet to both sides then, using the original board as a template, cut it to shape using a knife. As a finishing touch, I added some 12mm wide foam rubber tape around the edge:
https://www.amazon.co.uk/gp/product/B00XH8XXBK/
This was the end result, which I'm quite pleased with ...
Name:	2016-05-22 15.25.31-1.jpg
ID:	13396Click image for larger version
Name:	2016-05-22 15.25.49.jpg
ID:	13397Click image for larger version
Name:	2016-05-22 16.01.04.jpg
(I added the penny washers to prevent the screws from damaging the foam backing).
Old 23rd May 2016, 11:39 AM
Nice job Mark.
Old 23rd May 2016, 11:41 AM
Nice job Mark.
Indeed, A job well done!
Matt
Old 23rd May 2016, 01:14 PM
Great Job Mark!
Can you make up a load before the annual meet?
I'll definitely have one off you - Soul Colour Trim / Carpet please!
Old 23rd May 2016, 01:32 PM
Great Job Mark!
Not bloody likely I'm afraid. It took me about 2 months to find the time to make that one!
Also, it goes behind the carpet and mats, so the colour is unimportant. The originals are all beige/cardboard colour.
I do have a large piece of Nassboard left, if anyone wants it. Free to a good home (bad homes also considered). There's probably enough to make another 2 covers at least. I've also got plenty of foam rubber tape (for around the edges) but none of the foam rubber sheet left (though that's readily available on Ebay).
Old 23rd May 2016, 04:08 PM
Very neat. Something I'd thought of doing, but couldn't think what to use of the back. Do you still have the eBay number of the foam backing you used?
Old 23rd May 2016, 06:00 PM
I was hoping nobody would ask that!
I bought it for something else, over a year ago, and I couldn't find it at the time of posting, but after a bit of digging through old emails, it seems it was Ebay item ID #111227726521:
http://www.ebay.co.uk/itm/BLACK-NEOP...-/111227726521
(3mm thick is what I used).
I was just using what I already had, although it is very similar to the original foam backing. It's available from numerous sellers it seems and it appears the same stuff is available in a self adhesive form too. Spray-mount adhesive works well though.
Old 23rd May 2016, 06:05 PM
Someone has to ask these awkward questions Mark And what do you know, they don't post to Northern Ireland.
However, as you say, there are others selling it as well, so it gives me somewhere to start looking. Thanks.
Old 23rd May 2016, 06:24 PM
No problem. What you're looking for is neoprene sponge/foam sheet. Check that it's 'closed cell' (ie doesn't absorb water) and that it can be glued (if not buying the self-adhesive stuff).
The image in the ebay listing I posted is misleading, making it look like a rough foam. It's actually very smooth/soft to touch, with a fine/small cell structure, similar to the original foam backing.
EDIT: If you can't find a seller who delivers it to NI, let me know, I can order some for you and bring it to the meet (assuming you're going).
Old 23rd May 2016, 06:46 PM
Cheers Mark, but had to cancel the annual meet this year. It was either that or the 'ExplorA8tion Ireland!' one.
Managed to find ones that supply to Northern Ireland, so all the bits ordered. That's yet another little job to do to the car now
