Old 2nd May 2019, 07:06 PM
Spanker's Avatar
Spanker Spanker is offline
Thumbs up A day trip to Mackie's in Glasgow
The other day (Friday 26th April 2019 to be precise) I took my car in for a gearbox service at Mackie Automatic Transmissions Ltd (Mackie's) at 95 Causewayside Street, Tollcross, Glasgow, G32 8LT
I turned up at 8am, which was their opening time, and left the car for a standard gearbox service. The cost of the service was due to be £155 + VAT for my 5 speed ZF 5HP24a - the "bank account clearing" chunk of metal bolted to the undersides of the S8 D2.
The 6 speed box has a service cost in the £300+ range.
(you can read more about the gearboxes on Ian's thread here)
I took the car for the gearbox service for two reasons.
1. The S8 had received a gearbox oil change in the past according to some paperwork that came with the car, but I wasn't overly confident that it had been done or done correctly.
2. There was a slight whine on acceleration that I wanted diagnosing.
But why did I take it to Glasgow from the East Midlands? Well, I was up in Manchester for a film premiere the evening before so was halfway there, and I also got wind of a mini-meet in Glasgow, a town that I had live in twice before (Rutherglen). So the attraction to the other side of the border was quite strong, especially since I had heard good things about Mackie's.
I could have gone to Chester Automatic Transmission Centre but as I was to find out that day, Mackie's actually do some work for Chester Transmissions. The web address for Chester Transmissions is www.transcentre.co.uk. I wonder if they regret choosing that URL back in the day
After leaving the car I got the bus into the city centre to visit some of my old workplaces but by 2pm I decided to journey back to see how things were faring. I had expected a call by then but as I hadn't received one, I thought I'd spend the afternoon in their waiting room.
When I arrived back I was greeted by a gent who, with a sharp intake of breath and a shake of the head, proceeded to tell me that there had been issues!
Apparently, the technician had struggled for a long while to remove all the corroded bolts holding the sump in place and was now cautiously drilling them all out to fit Helicoil screwlocks. In my innocence, I thought this just meant that I would have an extended delay. Little did I know that it would cost me a lot more than that
Anyway, I sat down and enjoyed the coffee until I saw a framed poster on their office wall behind the counter:
Well....... it would be rude not to
So after a little wait, I was called from behind the counter to start my tour behind the scenes
I was permitted to take some photos in various places and I listened intently to everything that was told to me. However, I have forgotten a lot of the valuable info imparted so instead I'll show you just a few images to give you a taste of what their operation is like.
First stop was the booking-in area (I soon found that the place was very compartmentalised).
This is where they book-in and inspect the gearboxes. To the right, just out of shot are the cleaning bays (of which there are many around the huge workshop) and behind me were racks of checked-in gearboxes waiting their turn for treatment.
There were quite a few from Kia and Hyundai as Mackie's have a contract with them.
The next bays shown to me involved the stripping down of the boxes.
As you can see, they don't like working with anything dirty and I was surprised by the relative cleanliness (in terms of a workshop) of the place and the cleaned gearbox parts that they are working with.
The floor has these blue rubber(?) squares all joined together which were a little slippy underfoot but I guess are much easier to clean than concrete and much more forgiving on a part should it be accidentally dropped.
After removing the sump and valve body (behind this bay)........
It's time to clean and recondition the clutches......
These clutches appeared to be rather complicated things to me
If you want to see how complicated they are, try looking at the first three posts on this other forum thread.
You may notice in some images that some stainless equipment has a Mackie logo on it, like this diagnostic machine.
These are machines that John Mackie has developed over the years and are now made for other workshops.
In this image, you can see a gearbox test taking place. This room was like a sauna!
The gearbox is wired up in a "life support machine" kind of way and put through its paces. It's a noisy place too!
Just under the "Danger Hot Oil" sign, you can see a dark metal plate.
These are custom produced by Mackie's with their own CNC machine and are specific to each type of gearbox.
Here you can see the rack of support plates that the gearboxes are attached to. Can you spot the 6HP plate?
This is one of the machines developed by Mackie's. It's a valve body diagnostic machine. Quite impressive.
Roll up, roll up! Get your torque converters here!
These toroidal chunks of metal transfer the energy from the engine to the gearbox.
"In brief, the torque converter is a type of fluid coupling, which allows the engine to spin somewhat independently of the transmission. It is responsible for pressurising automatic transmission fluid - a pressurisation that supplies the force necessary to shift transmission gears."
For those not used to this concept (like me), you can get a better idea in this video.
Here's one that has been cleaned and expanded for reconditioning:
And this old thing is from a GM production line from a long time ago.
Apparently, welding the torque converter seems around the edges of the metal doughnut is not such an easy thing to do by hand if you want a perfect job doing. Who knew??
The all-essential torque converter balancing machine.
Sealed and cleaned (sometimes by sandblasting) before compressed air is blown into them underwater - like you would test a tyre underwater to make sure that there were no holes.
Next comes the dispatch area once things are all fettled and fine-tuned.
If like me, you're a fan of The Proclaimers, you may be familiar with one of their songs called "Throw the 'R' Away"
It's about the Glaswegian guttural "r", pronounced at the end of words, which could be lost within a generation.
Well it seems that Mackie's are playing their part in this cultural change with their packaging.
Either that or they have such a contempt for anything European that they can't bring themselves to say the word..
(Hint: check the wording on the white box )
Until now, all of the above had nothing to do with my car, as nothing required reconditioning.
Here is the technician who worked on my car, prior to him doing a test drive.
I asked him about the whine on acceleration to which he replied "what whine?".
And since driving the car since the service I can understand his reply as it is now without the whine (although he did do a test before the gearbox service so I don't know why he didn't spot it then as I told them about it ).
I thought I'd throw in a quiz question here....
Is that my car (D2 S8) on the lift in the foreground? Basically a bit of wheel and undercarriage.
Do you know the underside of your D2's well enough?
Or not? (MJ is excluded from this as this would not be a challenge for her).
So....
On to the oil change.
The machine that does the magic is called (by Mackie's) the "Hot Flush" machine.
I've seen it called the "slurpy machine" or the "pushy / pully machine" and other variants, but this is what it looks like in the flesh.
And once that had done its job (and the sump was cleaned and fastened on with the aforementioned fasteners), the car was test-driven and I was back in the office for the bill.
I was expecting £155 + VAT for the job but it was at this time, after all but two staff had gone home, that the subject of the "extra hours" work needed to be discussed.
"How much were you quoted??" said the foreman behind the desk.
"£155 + VAT" I replied
"For an S8??" he quickly responded...
"Yes. I was quoted £155 + VAT when I booked the appointment over the phone earlier in the week", said I, knowing that the person who had quoted me was Lisa Mackie, who was the only other employee in the building and was sat in the same office. She sheepishly did not look up from her computer screen.
The foreman muttered something about the S8 been more difficult to get to because "of the extra hardware" that needed to be moved out of the way. I did not have the knowledge to challenge him on that.
"And then there is the extra 5 hours that our technician has taken to drill and re-tap the sump holes".
Annoyingly I said that to spring such a thing on me at the 11th hour without consultation was a very poor practice (or words to that effect).
We finally agreed on me paying an extra 3 hours for the 5 hours of supplementary work, which at £75 per hour + VAT, brought the total bill to about £456.
An expensive day, what with the fuel and Travelodge, but a great experience topped off by a pub classic in a Wetherspoons in Helensburgh with some rather charming people.
And the gearbox appears smoother and definitely quieter
And finally, just in case you couldn't read the mantra on Mackie's wall in the previous image......
Too Much...or...too little
There is hardly anything in the world that some man cannot make worse and sell a little cheaper.
The people who consider price only, are this man's lawful prey.
It is unwise to pay too much, but it's worse to pay too little.
When you pay too much you lose a little money, that is all.
But when you pay too little you sometimes lose everything, because the thing you bought is incapable of doing the things you bought it to do.
The common law of business balance prohibits paying a little and getting a lot.
It can't be done!
Aye, right!
(or as us Yorkshiremen say in fewer words: You buy cheap, you buy twice!)
ID:	21532   Click image for larger version
ID:	21533   Click image for larger version
ID:	21534   Click image for larger version
ID:	21535   Click image for larger version
ID:	21536   Click image for larger version
ID:	21537   Click image for larger version
ID:	21538   Click image for larger version
ID:	21539   Click image for larger version
ID:	21540   Click image for larger version
ID:	21542   Click image for larger version
ID:	21543   Click image for larger version
ID:	21544   Click image for larger version
ID:	21545   Click image for larger version
ID:	21546   Click image for larger version
ID:	21547   Click image for larger version
ID:	21548   Click image for larger version
ID:	21549   Click image for larger version
ID:	21550   Click image for larger version
ID:	21552   Click image for larger version
Dean
Old 2nd May 2019, 07:43 PM
No photos. Is that just me? And I seem to recall that this is not the full story of your Glasgow visit!
Old 2nd May 2019, 07:47 PM
Spanker's Avatar
Strange
They show at my end.
I'll edit and see what happens.
Dean
Old 2nd May 2019, 08:00 PM
None showing for me either.. at least not embedded they are visible at the end of the thread
ETA OK now
Audi S8 2002, Black (even the chrome bits)
Audi RS6 Avant 2008, Daytona Grey
Maserati Granturismo 2008, Metallic Nero Carbonio
Old 2nd May 2019, 08:05 PM
Spanker's Avatar
I've edited the images and reloaded.
Checked on another PC (different location) and on a mobile and they show for me now.
Visible at your end?
Dean
Old 2nd May 2019, 08:34 PM
I see the photos. Great report Dean. Added to my bucket list of places to visit.
Old 2nd May 2019, 08:43 PM
tintin tintin is online now
All visible here too: great write up, and makes me feel less guility for not taking pictures on (my several!....) trips to Mackies. And MJ has a storytelling competitor now
Old 2nd May 2019, 09:28 PM
Great write-up! I never cease to be amazed by the people who can take a table full of bits like those photographed and put them all back together again... properly, and with no pieces left over.
Old 2nd May 2019, 09:33 PM
gninnam gninnam is offline
Like the story and £500 quid to now know your gearbox is going to be good for many years to come is well worth it
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 2nd May 2019, 09:45 PM
Spanker's Avatar
Just realised that some images were in the wrong order. Corrected this now (I believe).
That's true! I also recall debating Brexit with 3 overly aggressive () S8 Remainers.
Dean
