Old 23rd March 2020, 07:57 AM
edinko's Avatar
edinko edinko is offline
Default HELP Coding A8 D2 W12 hot/cold countries.
Hi guys, after i have done ton of work at car, it decide to "forget" coding for hot/cold countries (battery dead for month or so...).
Because my car is from factory coded to cold climate countries, and cooling of engine is not suitable for my country, i need to code it for hot countries.
I have read on measuring block 132 with VCDS and on the picture 1 is confirmed that code is for cold countries. That does not open the thermostat earlier than 105c and other following instructions as for the hot countries coding.
On the second picture is actual coding for my engine (cold one).
I can solve my problem to go at AUDI dealer, but since it can be coded, no reason to waste money on that. and this corona virus **** that have happened to us not helping, service is closed for who knew how long.
Someone who have VCDS and W12 A8 D2 can help me to read their engine coding, that can be seen on second picture.
Or if someone knew different way codes or anything i will be thankful.
God loves speed.
Earth orbital speed is 107200 km/h.
And someone set speed limit on earth at 50km/h. Well road safety they say. I say that is bad engineering
THREAD WITHOUT PICTURES IS LIKE SKY WITHOUT STARS.
A8 D2 W12 6.0l 2002
A8 D2 2.5 TDI 2000
S8 D2 4.2 V8 1998 Manual transmission
Old 23rd March 2020, 07:59 AM
edinko's Avatar
here are pictiures:
ID:	23046   Click image for larger version
God loves speed.
A8 D2 W12 6.0l 2002
A8 D2 2.5 TDI 2000
Old 23rd March 2020, 09:21 AM
Elsawin has this to say about it:
Your coding is for EU4 configuration. I suspect you may need 26753 for 'vapour-pressure-critical countries'.
There's no login procedure described for coding the ECU (unusual) so you should simply be able to enter the new code in to VCDS. Remember to do both ECUs
Old 23rd March 2020, 05:48 PM
edinko's Avatar
@MikkiJayne thank you, for help and information.
I have came to same conclusion that there is no Binary coding available in this case.
Probably coding is to complex, and it is easier to make precoded maps in the ECU, and just to choose wich map you need.
God loves speed.
A8 D2 W12 6.0l 2002
A8 D2 2.5 TDI 2000
Old 25th March 2020, 12:42 PM
edinko's Avatar
I have try to change coding, but after i click do it button window is closed, no additional infos or notifications.
But coding is not applied a change. Still remain same coding as before.
I think problem is in VCDS or cable.
God loves speed.
A8 D2 W12 6.0l 2002
A8 D2 2.5 TDI 2000
Old 25th March 2020, 01:20 PM
edinko's Avatar
Cool
I think this is cause of problem, the wery last sentinence.
God loves speed.
A8 D2 W12 6.0l 2002
A8 D2 2.5 TDI 2000
Old 25th March 2020, 02:07 PM
VCDS can definitely recode Motronic 7 ECUs (and others) - I've done it myself on V8s and TDIs. However, in order to recode it you have to log in to the ECU with a specific code. Only then will it accept the new code. There's nothing in the W12 documentation about logging in, which surprised me, but it may simply be an oversight.
I will have a look and see what the code is for the V8. As both ECUs are ME7.1 it might be the same on the W12.
Old 25th March 2020, 04:03 PM
edinko's Avatar
Im in your mercy. And that login procedure is on same window where is exicuted coding or before. I have not done that kind login before.
God loves speed.
A8 D2 W12 6.0l 2002
A8 D2 2.5 TDI 2000
Old 5th April 2020, 08:02 PM
edinko's Avatar
Well i have found time to google about login to ecu. Now i need code to apply procedure,
Maybe code from V8 is same for W12 because they use 2 ecu module and same generation.
If you can find your code to try loging in with that.
God loves speed.
A8 D2 W12 6.0l 2002
A8 D2 2.5 TDI 2000
Old 7th April 2020, 01:19 PM
27litres's Avatar
27litres 27litres is offline
27 for Brazil...
Would that be for the ethanol content in their fuel?
Min 25% up to 100% blends 😲
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
