Old 15th June 2012, 07:38 PM
Default D3 4.2TDI DPF Pressure Sensor
Apologies for my first post being a request for help but I have been a lurker for a while and an A8 parts customer
I have a 2005 A8 4.2 TDI, circa 125K miles on the clock and it has just started showing an amber engine warning light, I have checked with VCDS and the following error is showing. Clear the code, the light goes out for a day or so and then returns.
Address 11: Engine II Labels: Redir Fail!
Control Module Part Number: 4E1 910 409 A HW: 4E1 907 409
Component and/or Version: 4.2L V8TDI G000AGSª0070
Software Coding: 0011773
Work Shop Code: WSC 00503 503 81333
VCID: 22400330FDD4D09
1 Faults Found:
012298 - Diesel Particle Filter; Differential Pressure Sensor; Bank 2
P300A - 003 - Implausible Signal
Freeze Frame:
Fault Status: 01110011
Fault Priority: 0
Fault Frequency: 1
Mileage: 200079 km
Time Indication: 0
Date: 2012.06.13
Time: 20:08:43
Freeze Frame:
RPM: 0 /min
Pressure: 0 mbar
Pressure: -21 mbar
Temperature: 87.0°C
Temperature: 87.0°C
(no units): 0.0
Pressure: 0 mbar
Google suggests that I need to replace G450 or possibly G451 sensor? Has anyone come across this before or can you give me any tips? Is the part something that is best from a dealer or elsewhere and where will I find the sensor on an 8?
Thanks in advance
Paul
Old 15th June 2012, 08:42 PM
47p2's Avatar
47p2 47p2 is offline
It could be the filter is choked, there are products available to clean them out
Nite Blue 3.0L SE Quattro
Old 15th June 2012, 10:35 PM
I think the DPF is okay in itself, I think the sensor is the problem given the "Implausible Signal". I have found the code for other VAG engines and the fix seems to be to change the sensor, just not sure where it is on A8
Old 16th June 2012, 07:03 AM
47p2's Avatar
I found the number G524 for bank 2 sensor and G505 for bank 1 sensor
See attachments for location of connections and sensors
Hope this helps
Name:	Sensor connections.png
ID:	3871   Click image for larger version
Name:	Fitting location.png
ID:	3872   Click image for larger version
Old 16th June 2012, 08:23 AM
david@a8parts david@a8parts is offline
Director at A8 Parts
I agree with your thoughts, I'm sure the DPF will be OK it is just the Pressure Difference sensor that is unable to calculate the difference in pressure before and after the DPF therefore it cant decide how clogged or not-clogged it is.
Note that while it is broken it wont try and do any re-generation of the DPF so I would suggest a replacement sooner rather than later. I had to change the one on our Crafter for the same reason, easy job, and afterwards I used VAS to force a regeneration although I dont think that is vital - once fitted it should sort itself out.
We can get hold of one from TPS if you need, just let us know via email or a call on Monday morning.
At Work to Break:
2001 TT 8N 1.8T Quattro with a loud exhaust!
2000 A8 D2 3.7Q Non Sport Ming Blue
1999 A8 D2 4.2Q Non Sport Santorin Blue
2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather
2001 A2 1.4 TDi
2006 A6 C6 2.4 Quattro Avant Canyon Red
At Work to Drive:
1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch
1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash
2008 Fiesta Sportvan x2
2002 Transit 2.4 LWB
2007 VW Crafter Recovery Truck
2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart
2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses.
At Work to Hire:
4x 6 Berth Sunlight Motorhomes
Old 16th June 2012, 09:36 AM
If it is expensive, I would put the money towards having the filters taken out of their boxes and trashed and then ECU reflashed sans DPF.
I had mine taken out at 175,000miles due to blockage and it is much better without. You have two and it costs about £2400 to replace them!
Old 16th June 2012, 12:09 PM
Default What a great forum!
Ah, okay so looks like I need a G524 then Shame it looks a bit of a pain to get too "on gearbox rear" but I will give it a go!
I was working form what I could see in this doc http://www.volkspage.net/technik/ssp/ssp/SSP_365.pdf but the info posted above looks more specific to my car so many thanks 47p2
David, I will send you an email shortly and would be very appreciative if you could source the part for me Will try and get it fitted ASAP and post back how I get on.
Thanks to all
Old 16th June 2012, 02:50 PM
47p2's Avatar
Bank 2 looks to be sensor G505, double check numbers before ordering!!!
Also see attachment for sensor G450 which is the exhaust pressure sensor
ID:	3876   Click image for larger version
Name:	Exhaust pressure sensor G450.png
Old 18th June 2012, 08:39 PM
Well guys, having been under the car and re-acquainted myself with ELSA I am now wondering who in their right mind in Germany decided the est place to mount the sensor was on the TOP of the gearbox!?
£60 for a part, I suspect it will be a lot more in labour as lowering the subframe isn't something I want to try on the drive with a trolley jack and stands
Will call around tomorrow and hope that the actual labour involved isn't as bad as it sounds! Thanks for the help thus far
Old 19th June 2012, 09:01 AM
I am glad I was sat down when I called my local dealer for a quote, 7.5-8 hours @£145 per hour +VAT, so over £1,300 in labour, oh and £47.86 for the actual part
Actually it was worse than that, their tech suggested it was actually the lambda sensor as "your car doesn't have a DPF sir"! When I explained that it clearly did have TWO of them and maybe he should check they spoke to the master tech who advised that apparently they need to "remove the gearbox", which is weird because that's not what ELSA says but what do I know!? In any case, not very confidence inspiring!
Now awaiting a call back from a couple of indi's who hopefully will know their arse from their elbow!
Tags
4.2tdi, dpf, pressure, sensor
