-   D2 - Transmission (https://forum.a8parts.co.uk/forumdisplay.php?f=27)
-   -   Transmission Output Seal/flange (https://forum.a8parts.co.uk/showthread.php?t=10297)
David's8 26th July 2015 01:25 PM
Originally Posted by Adrian E (Post 97298)
The rear seal leaks diff oil rather than gearbox - only holds about 1 litre but makes a hell of a mess when it is leaking even fairly lightly. Don't think there's any breather on it?
Yes, as Adrian states, the final drive is total separate from the gearbox. It drips gear oil onto the cat and the burning smell/smoke is a good indicator.
Mechcanico Lee 26th July 2015 03:12 PM
So on the main gearbox where the prop comes out that has another section that holds ep oil ?
Mechcanico Lee 26th July 2015 03:13 PM
Is the 4.2 tdi d3 the same
Adrian E 26th July 2015 03:18 PM
Yep, that's basically it. Has a separate drain and fill on that part of the case
Mechcanico Lee 26th July 2015 03:39 PM
Yes can see it on a picture now , it has a prop that comes forward to drive front diff , I wonder if they suffer the same as land rovers where auto oil gets past the case seals and fills the diff part part with auto oil , it turns the ep oil pink and often spews out of the breather tube
