With 4 identical drives in RAID5 am I likely to get away with a single drive failure and rebuild (ie is it likely any missing segments of date from a failed read will be available from elsewhere in the RAID?)
I was running mirrored with 2 drives but ran out of space, so expanded it with 2 more drives and went to RAID5 at that point.... |
I think I might try ESXi on USB and use all for HDD's in 1+0 then |
Having said all that, there's a chance the drives might last better than expected and rebuilding may well succeed, but if you want to vastly improve your chances, with 4 drive bays, you could create a RAID 10 array instead. |
Years ago I had a home server, with 5 x 200Gb disks, and indeed 3 of them failed over a very short period. Now I have a NAS.
When my work HP server starts wobbling, it will be replaced with a NAS. I can't see the benefit of a server, and its complexity and expense, over the simplicity of a NAS. |
Of course a proper server can do so much more than any NAS though and in most larger businesses you'll usually find several of each, all serving different purposes. One of my customers is presently running 16 servers (6 physical and 10 virtual) and 4 large capacity NAS units (for shared storage and backups). |
I had two NASes before but they were too slow, underpowered and lacked flexibility so I ditched them and bought Dell server. 20-30MB/s transfer speeds from NAS were not good enough for me, on Dell I am getting 110-112MB/s which is pretty much the limit of 1Gbps network. Besides that fully blown server lets me run all kinds of software say the same ElsaWin installed on server and then PC/Laptop only need small client installed. It also runs CCTV, acts as a router as I ditched BT Hub and I am just using open reach modem and then Cisco access point for wireless, it does VPN to log on home network remotely and some other soft as well.
Installing ESXi did not go to plan it wanted at least 4GB of RAM but with 4GB installed there is only 3.84 available. I will update RAM in the future but just want to get it up and running at the moment. I do not really need ESXi as I don't need to run several virtual servers anyway so might go for 5th HDD in ODD bay as I have several 2.5" HDD's lying around just need to get power cable adaptor from FDD to SATA. |
1 Attachment(s)
This is what you need .... some serious server power (notice the 24 logical processors and 72GB of RAM) :) Attachment 11974 This is a setup I've been working recently on for a business customer. There are 4 servers in the group: 2 of them are of the spec you can see in the screenshot and the other 2, which only have 12GB of RAM each, are running the free Hyper-V 2012 R2 'core' OS (but can be managed from any of the full Server 2012 R2 Standard installations). The best thing about MS Hyper-V is how you can 'live-migrate' VMs from one physical server to another with zero downtime. I also have some of the VMs configured for replication such that, if one server dies, I can quickly power-up VM clones on another server in the group. |
The days of servers having storage are limited (well, over in most cases) Separating compute and storage makes sense full stop. When storage is all in one place its a lot easier manage. When compute breaks, throw it away and get a new one. You've lost no data. I run a Synology NAS at home, and feature wise its dripping with them, performance wise the 1GB lan is the bottleneck every time. Power, it uses very little. It also has a lot of apps available, including CCTV. All compute is on ESXi as its just easier (and cheaper) that virtualising over windows. In terms of raid, even at home, losing access to data whilst you restore from backups is a pita. For that reason alone, I would run at least Raid 1 to give you a chance of keeping things going whilst you replace the failed disc. Also, mirroring from a 4TB disc to 2 spanned 2TB discs, if even possible on a desktop O/S is a bit messy. Mirroring is best performed across identical geometries, however any mirroring beats none at all. |
