-   D2 - Engine Bay (https://forum.a8parts.co.uk/forumdisplay.php?f=20)
-   -   Smokey front offside? (https://forum.a8parts.co.uk/showthread.php?t=15606)
Green Goblin 17th April 2020 07:12 PM
Originally Posted by steamship (Post 156800)
A somewhat appropriate reference in the current climate with all the toilet roll hoarders! +++
The 3 seashells would stop all that :D
Anyway, will never tire of that movie. Absolutely love it.
Cocteau: "be well" Spartan: "Be f****d" :ROFL:
Don't make 'em like that anymore...
Just slightly off-topic lol
Davey Blueeyes 5th May 2020 10:39 AM
Just a quickie, can someone point me in the direction of the correct cam cover gaskets for my 2.8 Quattro please?
Found a garage that's open for key workers, hooray! I'm pretty sure the oil leak is this, as MJ pointed out and I want to ready myself for the normal island reaction of 'can't get the parts mate'! Plus they can replace the brake fluid while it's in there. I'm assuming it's Dot 4?
Thanks all, not easy getting stuff done at the best if times here!
MikkiJayne 5th May 2020 11:30 AM
Two of 078198025. Its used on loads of models so should be readily available from the usual suspects - Elring, Reinz, Febi, etc.
The brake fluid change is non-trivial on a D2 because of the ESP system. You have to cycle the ABS pump (with VCDS) in order to get it to flush properly and you absolutely must not let the master cylinder run dry otherwise all manner of pain ensues. You need a pressure bleeding system which can run at 2 bar to push the fluid through such as the Sealey VS820:
https://assets.sealeyb2b.co.uk/Image...4_DFC15460.png
A vacuum bleeding tool will not work as it can't pull the fluid through.
If the garage has one of these tools and an OBDII diagnostic machine then they should be able to do it. If not, I'd be inclined to wait until you can get over to Devon. The fluid is not in good condition, but I doubt a couple more months will be an issue.
Davey Blueeyes 6th May 2020 03:51 PM
Thanks MJ, that's awesome, thank you.
I've made a note and it's going in tomorrow. I have used them before and I think they are grateful for the work!
As far as I can tell they are the only one open here!
Davey Blueeyes 21st May 2020 10:48 AM
By way of an update and thanks to MJ's wisdom, the brake fluid has been successfully changed, yay!
The oil leak turned out to be the cam cover in the end so that will be a job for the next cambelt change should the car make it to that as it will be looking for a new home soon and hopefully we can find it one. It's too good for me to nick the fog light grills for my S8 and scrap the rest! :ROFL:
I hope you are all staying well in what's turning into a rather strange time down here?? +++
