ainarssems |
28th July 2011 04:50 PM |
Originally Posted by reiss
(Post 25376)
right changed fuel filter and its still showing the fault after reset! its now also showing cylinder 5 injector circuit malfunction! ive just remembered that i had the car recently mapped could that be causing the problem as i asked for the map to be more economical.:o
That means resistance for injector 5 circuit is out of specified range- either short circuit or open circuit. Check wiring and plugs for injector 5 for damage, corrosion and loose connections. Swap injector 5 with another one and see if the fault follows it.
Cylinder 5 injector sticking could be your issue. If you can swap the injector around and see the fault follow.
Sticking/clogged injector could result in lean readings and/or misfire but would not throw electrical circuit malfunction code. More likely to be loose connection either in the wiring or inside injector itself or damaged wiring.
I suppose mapping could result in running lean but I would concentrate on getting injector 5 sorted out first.
