-   D2 - Body and Exterior (https://forum.a8parts.co.uk/forumdisplay.php?f=22)
-   -   Wiper Arm - Excessive Sweep/knocking (https://forum.a8parts.co.uk/showthread.php?t=7167)
Green Goblin 25th March 2014 09:18 AM
Interested to see the outcome of this. I have the exact same problem - only does it on full speed. Car is a 2001 S8.
Dezzy 25th March 2014 09:47 AM
I'm always really anal when it comes to wipers as my linkage is a bit sloppy and a fair amount of play in the spindals, i'll not put them on untill the screen is wet, hardly ever have them on flat out and always set a intermittent delay that suits so there is enough water to lubricate (it's so handy ranging from 1.5 - 22 secs)
David's8 26th March 2014 12:54 AM
Havent got around to this job yet and wont be likely to until end April.
The_Laird 26th March 2014 08:06 AM
I wonder if we should strip my spare one when you get back David, rebuild it and then swap it out with yours? Then do the same for mine. That way we'd not be bothered about waiting for parts.
Dezzy 26th March 2014 09:44 AM
Recon exchange, good idea Jim +++
David's8 26th March 2014 11:18 PM
Sounds like a plan Jim. +++ It would be useful to find out just where the play is in the system.
David's8 20th November 2015 02:53 PM
Well, have just got around to this job and having replaced the wiper mechanism with a spare of the Laird's the issue has been resolved. On taking mine off one of the joints which appears to be a pressed ball and socket joint just fell apart. So the slackness in the mechanism caused by the wear in that joint was enough to allow too much sweep on the blades. +++
I'll see if I can get some photos but the Laird has my old mechanism for he spare motor.
Phil303 20th November 2015 06:41 PM
I've just replaced my wiper motor with a brand new one from Audi. After fitting, it turns out the old motor was fine.
If you want a working motor to go with a spindle set let me know.
David's8 21st November 2015 10:55 AM
Thanks for the offer but a good motor came with the spare mechanism and the Laird now has my old working one as a spare so all is fine for now. Its a treat not to have the damn thing knocking on the A-pillar when its raining.... which it has been doing a lot just lately.
sporran 21st November 2015 11:51 AM
I've got the same problem, only it's the passenger side that's thumping down on the plastic
Stevie
