Larger ET for 20 x 10
1 Attachment(s)
I've been asked if it's possible to use wheels with offset more than ET40. I think not. I did test the wheels before I put the tires on and I'm posting the result here.
The solution if you can't find anything else is to use spacers: http://raceland.com/audi-5x112-10mm-wheel-spacers.html |
Do you use any spacers? |
Can someone confirm what is the original tire and wheel size on S8 D2 final edition wheels?
I have 9x20 FE style wheels out of an D3 on my PF S8 with 275/35 tires and in it is quite horrible. The roads around here have grooves (?) due to studded tires commonly used in the winter, so the car with wide tires tramlines quite bad. I wonder why the previous owner chose the 275 width instead of 255, which should be ok for 9" wheel. |
I have 255/35R20 on my genuine FE 20" wheels (8.5"). I believe that is the correct size, it corresponds with the tyre pressures label.
Same here, I have 255/35R20 on my genuine FE 20" wheels (8.5")
Running them at 38PSI all round. |
Thanks! The next question would have been the tire pressure, but thanks johnny_quattro +++
