Ainarssems is right, +/- 0.3s is not very accurate. If you want accuracy best to look for a gps with sampling rate of 10 times per second, then accuracy should be +/- 0.1s
But, its good fun to be able to use VCDS, who wants to throw away £400 on a Performance box meter or similar. http://www.seatcupra.net/forums/showthread.php?t=87905 the cheapest performance mod is to run with your fuel tank almost empty. If its a 90l capacity, you could drop around 60kg, which could improve your 0-60 by around 0.2s |
1 Attachment(s)
Another big factor in this as you say Goran is weight, this is how the 8 looked when I did my run. I’ll remove it before I pick up that towel that Marcin threw down. http://forum.a8parts.co.uk/attachmen...1&d=1402310725 :snigger:
Try fitting the roof box to the bonnet next time, you never know, better aerodynamics may actually help you to break into 7.5sec :ROFL: If not, then park on the top of a long hill and then do the run (with the roof box still fitted to your bonnet :ROFL: :pint: for the 3.7s (the new 7.3) +++ I was pulling one of them last night http://static.businessinsider.com/im...in-caravan.jpg |
...and to shut Mr Dezzy :D PS. Dezzy, if you decide to to the down hill run to improve time, you may actually attach the trailer to the front bumper as it will take you down hill even quicker than without it +++ |
I'm loving this competition, can we make another A8 meet out of it with everyone cheering the two of you on? |
D2 Section 1. Tintin 2. The_Laird 3. Notorious D3 Section 1. Tonupkid 2. M-A8 3. MAM mutter mutter can't believe mine came 5th behind two 3.7s... the shame:o...... mutter mutter bah!! |
PS. Brian, could you post the amount of votes each car received, D2 and D3?? |
I cant believe you beat me! What with the highly desirable, classy vavona/twist interior (so much better than all black) ;) |
If we had a vote for who's the most competitive of our bunch, I think I know who'd win...;)
Marcin has it scribed on his sunvisor......:ROFL: |
