Goran - it'll just be a library photo on their Web site (from memory if you zoom in the part number doesn't match)
I'm picking them up this am so will post a pic Ainars - you're most likely right but I'm away next weekend and it may well be getting done next week or just after the bank holiday :) at that saving over tps prices I can't really complain :) |
1 Attachment(s)
Here you go - correct Bosch part number FGR6KQE / quick order code 7413
Made in Germany Happy days :) |
Thanks Adrian +++
I got e-mail as well. Says 'Daily Deal Ends Midnight Tonight'. I would not be surprised at all to get another one for 30% at the actual bank holiday weekend.
I am replacing clutch on A6, already have clutch bought 4 years ago but might need flywheel as well. Planning to take it apart tomorrow and will decide if flywheel needs replacing as well so hoping for even better bank holiday deals if it does. |
Thanks for the codes!
I'm now piling up a list of things I may need in the future. Surprisingly they even have a clutch kit for the manual S8! they even know the right gearbox code, DGV. |
BUR6EFSZ these are standard for my abz
BPR6EFIX-10 and thses are the iridium upgrade both ngk ill be looking for a set soon but i still get staff discount at the parts place i used to work soooo discount |
2 Attachment(s)
Got the set of Bosch plugs from ECP. The only issue is that i was unable to select "normal" free delivery and the only option was DHL at £5.95! However, at £50.27 for eight it was hard to argue. All fitted now +++ Next job, oil and filter change.
Mine went in yesterday - ONLY difference to the plugs that came out was the lack of Audi 4 rings logo. Bosch part number on the metal part of the plug was identical
Inerestingly 1 plug wasn't tight, which I think happened to someone else recently? Was blowing by the plug judging by the burn marks on the insulator. Was plug number 1 (front drivers side?) That was lose and no5 was v tight apparently. |
