-   D2 - Fuel and Exhausts (https://forum.a8parts.co.uk/forumdisplay.php?f=23)
-   -   Broken down (https://forum.a8parts.co.uk/showthread.php?t=1874)
Architex_mA8tey 4th July 2010 10:28 AM
Originally Posted by Singh (Post 13098)
Already sourced some RS 6 engines though ;)
LOL now youre talking Amar wooo :love:
Mr K 4th July 2010 11:48 AM
Excelent news! Im looking forward to this!
Singh 4th July 2010 08:30 PM
I shouldn't have got you all excited right away, I am going to meet Ben tomorrow to discuss the possible project in more detail. However, I'm not as good at being sneeky as Conan and R8_Dream!
Its going to be a lot of £££ but for something fairly bespoke. Clive said to me that a standard S8 handles like an RS 6 on coilovers, so imagine what an RS 6 powered S8 on coilovers could be like? The S8 is also lighter because of its ali design then an RS and imo has the better interior as well as being a lot rarer.
An RS with 517BHP does 0-60 in 3.6 secs, see below.
http://www.youtube.com/watch?v=R_AtRioAkNc
If I went ahead with this, rest assured it would have no less then 580BHP. (remember the S8 is a little lighter) +++
Mr K 4th July 2010 10:07 PM
excelent! It will be well worth it!
What box would you use? will the stock D2 box take it?
jayzee 13th July 2010 11:27 PM
Amar, I found this... http://forums.audiworld.com/showthread.php?t=1742729
The "lean" bit is interesting. Could this have been the reason for your engine failure?
Singh 14th July 2010 12:31 AM
You may have cracked it there Jayzee, that secondary injection valve was disconnected once. It didn't bring up a check engine light and I only discovered it as was doing a Vag Com scan. Ben clicked it into place again for me, but maybe it could have came lose again?Then the engine ran lean and died? :(
Don't think the rubber pipes around there looked excessive worn or cracked there though.
jayzee 14th July 2010 07:44 PM
Well, if this is the cause, then the hoses should be inspected and renewed if suspected to be on their way out.
I do note that on later D2s, the pipes are different - I'm going to check mine out to see if they are indeed the later type.
