Just follow Sergey's instructions for the correct fuse to pull - it sorted mine once it'd manually searched with the car out of the garage. Mine was probably a hardware issue in the dash cluster in losing the date....
Was your's a similar problem? And you simply pulled and replaced the fuse to cure it?
have tried that ...germany/france/spain ...no luck incidentally , my comment about the BBC and their thermionic valves is wrong....the BBC world service transmitters at Antham , near Carlisle , have been privatised ; as this is who the NPL pay to get the MSF signal broadcast I presume new kit will be purchased to continue the required service ; the range from here is a minimum of 1K Km , so not only the british isles is covered but much of western and northern europe |
There's still no antenna symbol or time change, but the date is there. Might try the manual method when I get a chance.
One question though, Sergey said that after a few failed synchronisations, it 'forgets' and goes back to a normal clock. Does that mean I have to do something (perhaps on the VCDS) to get it to 'remember' that there's a radio clock? |
The normal clock is pretty accurate and just keeps running.
If it loses the signal it does "try harder" to find it, the logic was posted earlier. Don't think it ever gives up once coded. Over a week now, could yours has failed? |
just noticed that the american WWVB signal works on the same frequency as the UK
wonder if these modules are available there |
http://www.ebay.co.uk/dsc/i.html?_fr...d2+819+403b%29 One in that list comes with the OEM bracket so you'd only need the self tapper screw to mount in the original position, but they're not expensive new from TPS - bracket and screws was about £5 IIRC (probably listed the prices earlier in the thread) There's a revised part number with an 'a' on the end which was OEM from 4D-Y-000 001 VIN but I doubt there's any practical difference The_Laird - have you done the fuse pull to reset the clock, then advance it to just before the time Sergey has posted that it will attempt to get a signal, lock the car and leave it parked outside for a couple of hours and it should have sorted itself out. |
