-   -   What's in the workshop this week? (https://forum.a8parts.co.uk/showthread.php?t=13403)
MikkiJayne 3rd September 2020 09:50 PM
Originally Posted by HPsauce (Post 159591)
My "theory" is that the Reverse circuit is the most vulnerable in that later design F125 because it actually takes all the current for the reversing lights, rather than just an electronic signal as I guess the other circuits do.
And it's actually 2 contacts for the full circuit, but one is a continuous track with no break, so it's almost inevitably the one illustrated that will burn out.
Though there is a corresponding mark on the other track presumably from the current load.
However sods law has determined that it's the P/N circuit (starter relay, very clean on your photo) that's given up on mine......
This contact was definitely only for the TCU, as the reverse lights and parking sensors worked perfectly with the stick in R, but the TCU couldn't see it. There was no gear indication on the dash (all the digits were white) and no engagement of the gear until the stick was pushed almost in to P, by which time the reverse lights had gone out. It made reversing on country lanes at night extremely challenging!
27litres 4th September 2020 02:27 AM
My "theory" is that the Reverse circuit is the most vulnerable in that later design F125 because it actually takes all the current for the reversing lights.
Surely only GM (Holden) are silly enough to use switches in that manner!
My first car was a Holden VB Commodore (GM Opel Rekord/Senator hybrid bodyshell, thus the Opel type naval nomenclature), which was basically a Holden built and engined 1st generation Carlton.
On this car, the Ignition switch took full Starter Solenoid amperage, the headlight switch took full headlight amperage, the brake light switch took full brake light amperage, and the demister switch took full demister amperage.
All these switches were simple contact slide switches, prone to carbon scoring.
There was a single main feed wire into the (simple) fuse box, which was about the size of a stock 20amp wire (about 2 - 2.5mm core) which had to carry all this amperage.
I used to get pulled over by other motorists (almost never cops, surprisingly) to tell me my brake lights weren't working (remember that type of courtesy?), which developed my regular checks in shop windows and such which continues to this day!
My headlights yellowed, my demister switch started to melt, my alternator failed about 3 times.
By the time I sold it, every circuit just mentioned had relays in place and the main feed wire was a double 30amp wire!
Bright headlights, no more brake light switch failures, no more alternator failures!
HPsauce 4th September 2020 08:04 AM
I'd be looking at the other set of tracks for the TCU gear-specific signals then, based on my understanding of how the F125 works. I can't see them in your photo, or all the contacts.
(I think I worked out the likely logic and posted it not long ago) Edit, here: http://forum.a8parts.co.uk/showpost....98&postcount=8 and http://forum.a8parts.co.uk/showpost....99&postcount=9
MikkiJayne 4th September 2020 08:08 AM
Interesting. I will have a look at the other side in a bit +++
HPsauce 4th September 2020 08:17 AM
I suspect that if the TCU gets an invalid set of signals from the other side of the F125 then it doesn't know what to display so you get nothing on the dash display.
The reverse light circuit contact damage was probably a red herring, just burnt from the high current but still functional.
HPsauce 4th September 2020 10:48 AM
By the way, have you worked out yet how that side is driven? If the shifter can only go as far as D or S does the gearbox move the F125 drive shaft when changing gears automatically and/or when you use manual override (lever on earlier version without S and/or tiptronic)?
Or is it just that on non-S models that's an input (gears 3 and 2) to the TCU that doesn't exist on S models?
Given there's no "1" position I'd guess that the TCU is informed by other means what the gearbox is up to and the F125 switch is purely an input mechanism, but why in that case is it mounted on the gearbox? It must be both an electronic input to the TCU and linked to a mechanical one to the gearbox (PND?), or is it just that directly mounting removes the inaccuracies of the cable linkage? :Confused:
MikkiJayne 4th September 2020 11:53 AM
The gearbox mechanically only sees PRND if memory serves (possibly one position after D - I'll check later). [edit - this bit is incorrect but left here for context later] The cable stops moving after that, and the other selections are done in the shifter mechanism which is connected directly to the TCU, so S, 432, and tip are all just software in the TCU. [/edit] The TCU definitely uses the F125 to know what mechanical mode the gearbox is in. There's no other sensing circuitry. Presumably ZF put it there as part of the gearbox design, and then left the selector mechanism and the actual software up to the OEMs.
This is why you can get S mode in an FL1 by changing over the TCU, although changing the shifter top is also important as if you put an S ecu in to 3 or 2 it gets quite cross! The only issue I've found so far with that upgrade is that the cluster gets a tad confused and tends not to display the gear selection at all. I think the later TCU sends a different set of messages for PRNDS compared to the early one for PRNDS432. I need to swap in an FL2 cluster which I'm sure will solve it.
HPsauce 4th September 2020 01:03 PM
Thanks MJ, having never looked at these in detail I'm just intrigued as to how it all hangs together.
I can understand that there has to be input from the shifter to the TCU - Tip+/- for a start, and the kickdown switch and probably many other sensors/controllers.
Presumably there's a link from the TCU to the gearbox (valve body?) to issue commands to change gears etc. does that have a feedback/control element too?
When you say "Mechanical Mode" do you mean just PRND (and maybe S/4) or also 3 and 2, which the F125 is theoretically capable of signalling?
Just wondering how/if the TCU knows when the gearbox is in First gear...… :Confused:
As for the cluster, presumably FL2 has a different bitmap or coding for the gearbox display vs FL1 as it has more options to display, so it's hardly surprising it gets confused and gives up.
I don't imagine the developers ever considered providing cross-compatibility either way between FL1 and FL2 TCUs and FL2 and FL1 clusters!
MikkiJayne 4th September 2020 01:53 PM
Its quite an interesting mode of operating actually. Left to its own devices, the gearbox will be a 1-speed hydraulic automatic, with P, R, N and D (3rd / 4th depending on model). The TCU actually overrides this behaviour by controlling the solenoids in the valve body, and monitors the results via the input and output speed sensors.
"Just wondering how/if the TCU knows when the gearbox is in First gear"
The valve body does only have PRND, so the TCU sees 'D' on the F125, and based on its numerous inputs it will select 1st using the solenoids. It doesn't know a gear has been successfully engaged until it sees some output revolutions, and it knows the gear ratios so it can calculate what the output speed should be based on the input speed.
When the TCU detects a fault (such as input rpms happen but output rpms don't) it basically shuts down and leaves the gearbox to its own devices and it reverts to the 1-speed auto, which is how limp mode works.
"I don't imagine the developers ever considered providing cross-compatibility either way between FL1 and FL2 TCUs and FL2 and FL1 clusters! "
The FL2 cluster is backwards compatible to PRND432 as not all FL2 had S mode, but its fair enough the FL1 cluster isn't forwards compatible :D
ainarssems 4th September 2020 02:17 PM
I am not sure if I understand this right but if you look at the testing for F125 from Elsa it has different outputs between different pins for D, 4, 3 and 2. As it's being turned by gearbox there must be something mechanically moving in the box when moving lever between D, 4,3,2.
