If anyone is looking at doing this, I spotted these S8 mirror caps with side assist cutouts:
http://www.ebay.co.uk/itm/Audi-Chrom...8AAOSwKIpWAcB8 |
Not genuine though :(
For Lane Assist retrofit wouldn't you also need the different indicator stalk, windscreen and windscreen camera/sensor?
http://i64.tinypic.com/dhcmyu.jpg http://i67.tinypic.com/11klhjb.jpg |
Nope as I'm looking to do Audi Side Assist retrofit ( Lane Change Assist). In elsawin Side assist is referred to as Lane Change Assist.
Can someone explain the wiring on the last page for me please. What happens at connection B565 in the main wiring harness... Do the wires from both doors join here to connect to pin T10v/4 to the bumper connection? I've got the following error message at the moment as a result of this.. Address 3C: Lane Change Labels: None Part No SW: 4L0 910 566 C HW: 4L0 907 566 B Component: J0769_SWA_MasterH01 0020 Revision: 00H01000 Serial number: 6PZ 009 014-10 Coding: 0010101 Shop #: WSC 31414 790 00001 VCID: 2E54842BB96DB53202-807A Subsystem 1 - Part No: 4L0 910 568 C Component: J0770_SWA_Slave_H01 X080 Subsystem 2 - Serial number: 6PZ 009 014-30 Subsystem 3 - Serial number: 5F21.11.0700H010003C910145ÿ Subsystem 4 - Serial number: 910145ÿ 3 Faults Found: 01517 - Control Module for Trailer/Towing Sensor (J345) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 227 Mileage: 123056 km Time Indication: 0 Date: 2016.08.18 Time: 17:55:32 02854 - Warning Lamp for Lane Change Assistance (in right exterior mirror) (K234) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 227 Mileage: 123056 km Time Indication: 0 Date: 2016.08.18 Time: 18:01:02 02001 - Data-Bus Automatic Distance Regulation 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 12 Mileage: 0 km Time Indication: 0 Date: 2008.01.01 Time: 00:00:00 Any ideas? Thanks |
Hey guys, quick question to owners who have side assist fitted from the factory. Can you kindly share the coding information from your modules so i can configure mine accordingly please.. many thanks
Part No SW: 4L0 910 566 B HW: 4L0 907 566 A Component: J0769_SWA_MasterH10 0130 Revision: 00H10000 Serial number: 6PZ 009 014-00 Coding: 0001109 Shop #: WSC 02313 785 00200 VCID: 2D12C920B4CC3B56E5-8079 Subsystem 1 - Part No: 4L0 910 568 B Component: J0770_SWA_Slave_H08 0130 Subsystem 2 - Serial number: 6PZ 009 014-20 Subsystem 3 - Serial number: 3F29.03.0800H0800000010155ÿ Subsystem 4 - Serial number: 010155ÿ No fault code found. -------------------------------------------------------------------------- Address 5C: Lane Maintain. Labels: None Part No SW: 4E0 910 217 C HW: 4E0 907 217 C Component: J759 LDW H07 0070 Revision: 00H07018 Serial number: 80020840800035 Coding: 0011202 Shop #: WSC 02313 785 00200 VCID: 200C2014F31EE63E5E-8075 No fault code found. Hope this helps +++ |
