-   D2 - Engine Bay (https://forum.a8parts.co.uk/forumdisplay.php?f=20)
-   -   Engine conversions for the D2 (https://forum.a8parts.co.uk/showthread.php?t=14883)
Goran 10th April 2019 09:46 AM
Ricky there was a Swedish RS8 on the forum (with RS6 4.2 engine), he used it mainly for racing.
There are youtube videos of it in that thread.
http://forum.a8parts.co.uk/showthread.php?t=9132&page=4
MikkiJayne 10th April 2019 10:36 AM
That also caught fire! Thats actually the one I was referring to when I mentioned heat management and packaging issues. The lengths to which he has had to go to stop it melting itself say 'not worth it' to me. The fire was caused by the heat from the turbos melting one of the camshaft end-caps so it fell out and poured oil on the turbo :eek:
The turbos on the 2.7TT are in the same place, but since its a physically smaller engine I'm hoping there will be more airflow in to the engine bay so it will stay cooler. I'm likely still going to either wrap the turbos or make heat shields for them.
Goran 10th April 2019 10:59 AM
That one burned down too? That is a real shame. Its amazing to see what people can do so I hope to see more unusual D2 conversions.
That's why I am scared of turbos and to some extent superchargers. All the extra components means more things to go wrong and more tweaking and solving to be done.
Also, life is short, I have driven D2s for 11 years now, whilst I'll never sell it, for my next car I want to try something different. C63 6.2 is high on my list, a lovely big German NA V8. Shame its not manual but you cant have everything.
MikkiJayne 10th April 2019 11:10 AM
The RS8 survived and he rebuilt it, but it highlights some of the potential challenges. Its one of the reasons I think the 4.0TFSI would work well, subject to the downpipes clearing the firewall. With the turbos in the V it not only makes the engine much more compact (so better airflow) but it is designed with heat management in mind.
Superchargers are much simpler overall for a small power increase but need a lot more fabrication so it depends what the goals and budget are really.
How fast can you afford to go? :ROFL:
You're right though - at some point it makes more sense to buy an AMG Black series!
Conan_the_Librarian 10th April 2019 05:46 PM
I've had an S8 with a theoretical 400 BHP! Great torque. Not too difficult. About 2 days work including testing.
ainarssems 10th April 2019 07:04 PM
Originally Posted by conan_the_librarian (Post 149593)
i've had an s8 with a theoretical 400 bhp! Great torque. Not too difficult. About 2 days work including testing.
n2o?
Damn auto correct does not let me write NOS or N2O on it's own in capitals.
Conan_the_Librarian 10th April 2019 08:23 PM
Indeed NOS. Never got to push the envelope. Must get back into it. I've still got all the kit in a box in the garage...........
27litres 11th April 2019 09:11 AM
I too wondered about LS's.
They're pretty cheap and readily available here, as they were fitted to local Commodores (Both LS1 and LS3), and from next year we'll see them back in the Camaro.
There's loads of aftermarket performance products for them including several different supercharger kits for well over 700hp (LS3).
But making them fit is an issue. And in stock form without any mods, they're not much more powerful than a 4.2 S8 engine (LS3 6.0 - 270kW), though the torque is quite something (LS3 6.0 - 530Nm). But it's taken them 6.0L to get there, so they should have a lot of torque!
The Coyote 5.0 is a cooler engine, with specific outputs matching those of the S8 4.2, and they can be supercharged too. But they're more expensive and quite large - I'm pretty sure they won't fit in a D2 engine bay!
Goran 11th April 2019 10:12 AM
I would really like to see someone do a LS into a D2 conversion, keeping the 01E or perhaps with the newer better 0A3 from B7. The torque is the fun part. I can tell you the stock D2 with a manual trans lacks low down torque in some gears, especially 2nd gear. In normal driving you want to change from 1st to 2nd around 2000rpm or less, then 2nd drops to around 1000rpm which is a bit low for decent torque.
Less weight also = better performance, and its interesting that LS3 weighs less than a AVP engine, so by converting it you are saving weight up front too.
Although the engine may be even more forward than stock.
People have swapped LS engines into all sorts of cars, Porsches, MX5s, BMWs, Nissans, etc. It seems to be one of the most popular engine swaps. It must be for good reasons, light weight, small pushrod engine package size, very good hp and torque. Simplicity, reliability.
Porsche swaps especially tell me something about the quality of these engines, Porsche is still quite a premium brand, for guys to be happy to swap a 'crude' pushrod engine into older Porsches is really saying something about the reliability of older Porsche engines vs the LS engines.
Although pricey, some of those Katech LS3 engines put out nearly as much torque and HP as a C5 RS6 twin turbo 4.2 for much less weight and complication.
Goran 11th April 2019 11:25 AM
LS3 swapped Jag, looks amazing!
http://www.speedhunters.com/2016/04/...ft-perfection/
