If it is a stuck piston in the ABS unit then maybe some percussive maintenance might free it up? Maybe use the wheel brace to get in between the pipework and give it a whack with something heavy. That might free it up, although it may well get stuck on the next press of the pedal.
Thats all I can think of other than getting it recovered unfortunately. Where are you at the mo? |
Currently in Stevenage, mechanic I trust is on London :( |
Does the letter at the end of pump part number matter?
Hard to say. I just put a 2002 S8 ESP control unit in a 2000 3.7 and it worked fine which would suggest little to no hardware differences.
I have 8E0614111AT for all FL with ESP which is compatible with suffixes AS and T. |
