I see what you are saying Ian and I think a bit of VCDS work and a trip to Maplins is coming on. |
Parallel is not logical (given how resistors in parallel work) and would not produce the results I measured and solution I used that was totally effective. The main squab and thigh pad are almost certainly in series and resistance reduces when the seat is occupied. My solution was to short the wires together for the thigh pad, reducing that measure to zero. The main pad, which seems more reliable, will (OK, should) still show the seat as occupied. If the thigh pad was faulty, giving a permanently high resistance (as mine was) then just sitting on the main pad would show the seat as occupied. That's not what was happening. And the VERY SIMPLE wiring suggests otherwise. Measuring both separately would need a different electronics module for that seat. Maybe it exists, maybe not.... |
There are, from observation and as described discussed here earlier, two separate pads but the wiring schematic, (probably for simplicity?), just shows a single sensor with 1 resistor and 1 diode. There are unfortunately no resistance values shown.
Can I assume that by shorting out the thigh pad, the seat occupied signal will work? I will try and check this today using VCDS - i might even ask The Laird to do a stint as a crash test dummy. :ROFL: |
So, having put VCDS on it, the measuring block show "Occupied" even when empty. (It showed sensor fault before). With The Laird gracing the seat it shows - as you might expect - that its occupied too. What does this show (if anything?) about the resistance?
1 Attachment(s)
Cheers Mark, attached. +++
1 Attachment(s)
1 Attachment(s)
And this is the sum total of what it says (Diode parallel to resistor). Note blue and white cables as expected:
just had a thought ; as everyone will have noticed it is possible to deactivate this airbag with a key ; so I wondered what happens if I do this ; so I deactivate and carried out the same test result ...exactly the same as before ...so what does this tell us ? just to be clear ......unmodified wiring ..... airbag activated code 656 airbag deactivated code 656 and to be extra clear , ~I just want the airbag working and the light off ...if the airbag goes off with no passenger , hard luck ...the insurance company is going to write off the car come what may |
From an electronics point of view, the purpose is usually to provide a very simple means of detecting different fault states. The resistor allows for differentiation between open/short circuit (if a simple switch were used, it would be impossible to tell the difference between a correctly functioning switch and broken or short-circuited wiring). The diode is probably serving as wiring polarity detection and further confirmation of a correctly functioning circuit. |
