None are the right shape/size for a D2 but the way they work is to use a small LED in place of the larger filament bulb. I'm pretty sure one of the many types they sell "could" be modified, probably by cutting down a bit and fitting onto a backing plate, to directly replace a D2 light. In general the newer ones that they supply alternatives for are not so "long" but a bit "wider". The A6 one looks pretty close. http://www.xcarlink.co.uk/product.ph...&cat=25&page=1 |
Nonetheless I'll check them after a while and see if there's any corrosion and take "appropriate action".;) |
1 Attachment(s)
Not wanting to rewire the (now botched) plug I bought the audio adapter pictured below which has the right 14-pin connector on it. I was going to cut off the two big sockets and just "graft/solder" it on to the loom (in place of the botched connector) but I'm wondering if I can buy plugs that fit those two sockets, anyone know what they are called? The actual cable is sold as "Kenwood Car Radio Stereo 14 Pin Molex Type Wiring Harness Loom Old Version ISO" so they may just be specific to old Kenwood equipment. |
1 Attachment(s)
1 Attachment(s)
Many thanks Matty, +++ so I need one of these now:
(might seem a bit complex but it will also add a bit of extra length to the loom which I really need) |
So can anyone point me at the "real" VIM solution for RNS-D please. ;) |
1 Attachment(s)
But then there are references to two different connections on the back of the RNS-D. 1. The clearly-identified GALA on an 8-pin connector (pin 1?) 2. A pin on the 26-pin connector, possibly #5, which seems to be marked DFA_L on diagrams I've seen. :Confused: (there's also a DFA_R) The Kufatec loom to do the job just seems to have 8-pin connectors (see picture) so I'd guess the switch on that just interrupts the first one. I could buy one as they are not expensive, but unless access to the loom is really tricky it's an easy DIY wiring job. And I prefer not to add even more wiring and bulky connectors into an already-congested area behind the RNS. Edit: Found the following, which sort of makes sense: 5 connection rear left speed sensor in dash panel wiring harness 17 connection reverse light in dash panel wiring harness 18 connection rear right speed sensor in dash panel wiring harness Though whether those signals exist and what the RNS-D does with them is anyone's guess.............. (Could be for features not yet developed or not used on a D2, RNS-D not being that specific, or more likely for the SatNav) |
Can't be bothered to take the glovebox out and side panel off to get at it, so Kufatec it is! :( (£25 delivered) Edit: Out of stock at UK distributors, back-order from Germany, hopefully less than 2 weeks. |
And checking connections it was pin 1 that the loom opens/closes, so: Quote:
And the SatNav will use the information from the 26-pin connector. |
I've just noticed a really stupid feature of the Kufatec loom. :(
The operating button (mine is round, not square as in the photo) has a nut and spring washer for securing it from behind (through a mounting hole), already fitted. Saves them getting lost presumably. But it is of course impossible to fit that way without cutting the cable to the switch, the button has to be inserted from the front! :eek2: So why didn't they put a small connector in that (2-wire) part of the loom, small enough to feed through a mounting hole and to slip the nut/washer over. Or provide a fixing that you attach and tighten from the button face side? So much for German attention to detail! :snigger: http://forum.a8parts.co.uk/attachmen...5&d=1477468085 As it happens I'm using a different switch so it's not an issue for me as I need to cut that wiring anyway. :p |
