Transferring from Coinbase may be quite useful since my current account won't accept incoming SEPA transfers, but after Coinbase's conversion fees I'm not sure its any better than selling on Bittylicious? |
Revolut accepts SEPA both ways but I think, more importantly, even if you could send directly to your bank, it's probably best you don't. Banks (perhaps unsurprisingly) have become a little uncooperative lately when it comes to cryptocurrency trading, with numerous stories of people having their accounts suddenly closed just for transferring funds to/from cryptocurrency exchanges. When you transfer to/from Revolut, the bank just sees it as a regular bank transfer from another bank account that you own. I've looked into selling on Bittylicious a few times, but never gone much further than that because I'm not planning to sell any of my holdings yet. As far as I could tell, it looks like you need to apply to be a seller and you have to have a certain amount of Bitcoin, etc available for sale at all times, and be ready to respond quickly when you receive a purchase offer. If/when I do sell, I think I'd prefer to be able to choose how much to sell and just exchange it. |
1 Attachment(s)
Having some extra time on my hands I have drawn my attention to GPU rigs again. Garlicoin was a bit of a bust, I have accumulated a bit over 180 of them now but CryptoNight still seems the way to go for AMD cards. Eth is up there but MRR pay well for XMR as well and it's lower power, temps and noise. So I have been looking at using my Onda motherboards and trying alternative miner software instead of Stak-XMR. I finally got SGminer to work which is supposed to be the fastest and no dev fee but I could only get about 650H/s out of it comparing to 800-900 on cast. XMR-tak was either slow with low intensity or crashing with high intensity for me but I really wanted to get it working due to several pool settings.
So my final result is this on Onda D1800 BTC motherboard http://forum.a8parts.co.uk/attachmen...1&d=1518032471 5x RX580 cards, XMR- stak, 4k+ H/s less than 600W. I was worried about close spacing of cards but temps are pretty much the same as before, fan speed might have gone up a bit in average maybe from 1200 to 1300 rpm. Well pleased with it although profitability has gone down a lot since mid December it's still better than it was in September. It's earning me more than £9/day, in September it would have been £4-5/day. Compares well to the S9 as well, the whole setup would cost about £1800-1900, only uses less than 600W and would be more re-saleable if all mining went downhill. Just need to do the similar setup on my other Onda motherboard but it will leave 1 card left over and as it is easier to manage the same cards together I think I will have Vega card left over so that will end up on eBay with £500 starting price as that is what my friend already offered me for it. Not bad considering I bought it for £390 and it has already earned me £250-300. |
Anybody else spotted Antminer V9 release?
Nice work on the Onda rig Ainars +++
Those cards do seem very close, but if the temps are ok I suppose that's all that matters ... How's the stability? Quote:
The downside with XMR stak is that at every startup it creates 4GB file in pagefile for each thread so 40GB in total so it takes 10-15 minutes to start up as I use older mSATA drrive on this motherboard which only does ~90MB/s write speeds instead of M.2 PCIe drives doing 500+MB/s write speeds I were using before. I guess Atom J1800 CPU does not help either. But once it's started it works just fine. Quote:
Besides I could use that money for soundproofing as my neighbour complained today about noise coming from my garage. Apparently he can hear it in the conservatory when he turns his radio off or in the house with window open. I can understand him and I have moved one L3+ in the house today and I am switching D3 off in couple of hours time when rental runs out to keep garage cooler for remaining 3x S9s and 1x L3 and hopefully reduce the noise by reducing fan speeds as until now the garage has been warmer than house:). Also sealed all the air gaps around the waves of roofing sheets and around the door with expanding foam to limit the noise escaping but that will potentially reduce ventilation and increase the temps. I already have some acoustic ducting to experiment with and some adaptors are in in the mail for me. Not sure where I go next with noise insulation, maybe use an old fridge or freezer to house miners or build some extra brick walls in garage for a separate section for miners.:Confused: |
Apart from an issue with a temporary cash point because i refused the fees, it didn't give me cash and it still showed up on my account, having to go through a 3 month charge back which timed out and then refunded....which i think was more the crappy german cashpoints fault than Revolut it's been a doddle. Bank rate transfers with no fees, upto a sensible limit (5k iirc) As for the referrer link, you needed 3 to access crypto currency early, but i've heard it's limited in use atm, so meh....i'll wait Antiminer V9....is that 4TH on Sha256 then....ok, only 1000w, but you get 4.7TH on an S7 for 1200 so it's nigh on the same efficency....OK it's only $345 but you need 5 of them and the psu's, plus tax, shipping and import, so probably not that far off the £750 i paid for mine with psu back in October and that's in March....Given the naff exhange rate atm and unpredictability, i think i'll pass |
Some speculate that V9 is old S7 boards from Bitmains own farms underclocked in new casing and maybe new controller. |
If you top up your Revolut account with a credit card, it seems the card company register it as a purchase rather than a cash advance. So, if you have a credit card that gives cash back on purchases, unless I'm missing something, you could top up your Revolut account, transfer the funds to your bank, transfer the funds from your bank back to your credit card, thereby receiving cashback without making any purchases. |
