-   D2 - Sat Nav, ICE, Audio & TV (https://forum.a8parts.co.uk/forumdisplay.php?f=38)
-   -   RNS d tv function lost. (https://forum.a8parts.co.uk/showthread.php?t=10275)
goldsax 9th July 2015 06:27 PM
Need some help please.
RNS d had been working great. But today when I pressed the radio/cd/tv button to select the tv function. The unit only switched between radio and cd. As if the tv function was not even there.
Will disconnecting it reset the unit? I have the 4 digit code.
Any ideas please.Cheers raj
HPsauce 9th July 2015 07:33 PM
I think detection of the TV unit is automatic; if it's not there the option doesn't appear. I'd check wiring and power to the tuner first.
And if in doubt a full power cycle may reset it.
There is no option in the RNS-D configuration for TV and when I added that input to mine it just appeared in the cycle.
goldsax 10th July 2015 06:42 AM
Thanks for the reply.
Full power reset meaning ...unplug the unit per supply and reconnect?
Thanks raj
HPsauce 10th July 2015 08:00 AM
Find the relevant fuse and pull it for a short time then re-enter the code; I've had to do that a couple of times in the past to reset my RNS.
Not 100% sure where the fuse is, on PF it was in the boot above the battery.
Just likely to be easier than taking the RNS out of the dash.
goldsax 13th July 2015 06:40 AM
i have the keys and was earlier to remove the unit and left it unplugged for 30 minutes and reconnected . i tried this 3 times.
it made no difference.
the radio stations were still remembered when reconnected.
i thought it would reset the whole system to factory setting. but apparently not.
so is there a way to reset to factory settings?
many thanks
raj
andycaca 13th July 2015 10:08 AM
unplug the tv unit in the boot and then plug it back in again?
goldsax 13th July 2015 10:03 PM
thanks for the reply.
still no joy.
tried searching the net, for hard reset and found that there is a way to ‘hack’ into the unit.
but feel a bit uneasy is the post warned that it could go wrong.
i wonder why its so hard/impossible to do a hard reset..
mannyo 14th July 2015 06:25 AM
Have you checked the fuse for the TV Tuner?
goldsax 15th July 2015 08:37 PM
disconnected battery for 10 minutes.
reconnected and the RNS works perfect.
wonder what happened?
thanks all for taking the time to help with this problem.
cheers
raj
HPsauce 15th July 2015 09:15 PM
Did you not try this?
