-   VCDS (aka Vagcom) (https://forum.a8parts.co.uk/forumdisplay.php?f=75)
-   -   VCDS Auto Scan cannot reach modules (https://forum.a8parts.co.uk/showthread.php?t=10542)
mattylondon 11th September 2015 07:19 PM
1 Attachment(s)
Not sure if this is a VCDS problem or a physical problem with the car. When I do an Auto Scan the modules cannot be reached (pic below). However all modules can be reached if I go directly into them and coding, measuring blocks etc.. work fine without any problem.
My last Auto Scan that worked was back in June on version 14.10.2.0 (x64)
Since then VCDS has updated to 15.7.0.0 (x64) & 15.7.1.0 (x64) and also the firmware in the cable has been updated.
Does anybody have any ideas that may help?
Cheers +++
http://forum.a8parts.co.uk/attachmen...chmentid=11835
Architex_mA8tey 11th September 2015 10:28 PM
When you update the software it normally asks you to connect the cable so it can "re-discover" connection method etc - did yours do this?
mattylondon 12th September 2015 09:32 AM
Hi Neil,
Yeah, the connection is fine. There was one error on the battery module because she's been parked up without a decent drive. I'll do some digging once the rain stops here and see if it's an energy management issue with the car.
mattylondon 20th September 2015 08:08 PM
Just to conclude this thread, it was a battery issue. Installed a new battery and VCDS auto scans fine now. +++
Adrian E 20th September 2015 09:09 PM
Usually if it's reporting battery voltage much lower than 12.5V anywhere it can start to go screwy it seems.
Glad it was straightforward to sort :)
