-   D2 - Interior (https://forum.a8parts.co.uk/forumdisplay.php?f=24)
-   -   C pilar removal ? (https://forum.a8parts.co.uk/showthread.php?t=11127)
brad131a4 2nd February 2016 05:13 PM
C pilar removal ?
Working on removing the interior of my car and seem to have run into a issue.
There is something not wanting to come apart on the top of the C pillar cover right at the top as it starts to bend done from above the door down the pillar.
Almost looks like there might be a screw on a tab under the headliner? Any idea's of what I'm running into.
I've looked at all the thread's in this section waiting to be able to post and haven't come across anyone else having this issue.
Thank you.
David's8 2nd February 2016 07:23 PM
Have a look at the Tech Dump in the D2 section for the "General Body Assembly - Interior" document. That should provide an answer. +++
Architex_mA8tey 2nd February 2016 08:12 PM
Here's the document you need - page 195 & 196 +++
http://forum.a8parts.co.uk/attachmen...9&d=1420350463
brad131a4 2nd February 2016 10:36 PM
Perfect just what I was looking for.
Thank you.
craig 3rd April 2016 07:40 PM
Hahàh I had this issue today striping out my car you have to take out the handle screw in the hole you will see a small cable work it out from its resting place its hard to see after you pulled it out pull with some pliers just enough to release the clip were the 1 that is stuck well stuck is not the right thing to say it's there so when air bag is deployed the panel stays there and don't hit you in the head the panel has a week spot like perforation along it behind I got pics if you want let me know
