-   D3 - Common Faults (https://forum.a8parts.co.uk/forumdisplay.php?f=67)
-   -   Audi 4.2tdi p0101 error (https://forum.a8parts.co.uk/showthread.php?t=11181)
yorkiea8 12th February 2016 06:04 PM
Hello
I got the engine warning light 2 weeks ago, when I scanned it with my torque app it ready p0101 air flow sensor issue. I reset the light and hoped for the best. Well it came on again today same error. Any advise on where to go from here?
Architex_mA8tey 12th February 2016 06:17 PM
Either clean or replace the MAF sensor, then clear faults and rescan +++
Mechcanico Lee 12th February 2016 06:54 PM
Can you look at live data with the app ?
yorkiea8 12th February 2016 10:21 PM
What should I clean it with? Sorry for being a bit thick. Will have a look at live data is there a voltage from the maf I should be expecting on idle for example.
yorkiea8 13th February 2016 10:07 AM
Is it an Audi job for the part or can somebody recommended anywhere else?
Mechcanico Lee 13th February 2016 12:19 PM
Go into data look at both air mass mg/str levels , at idle they should be about equal normally around the 400 mark , bring the revs up and look for them coming up as mirror image of each other , they wont be excatly the same .
yorkiea8 21st February 2016 08:39 PM
Hi, does anyone know where I can buy replacements. It's lost all power on full throttle so I just want to replace them.
Mechcanico Lee 21st February 2016 08:47 PM
Is it worth a code test first ??
