-   -   Subframe Mounts (https://forum.a8parts.co.uk/showthread.php?t=1119)
AndrewGray 5th August 2009 06:40 PM
Subframe Mounts
The subframe has 4 bolts that go through the subframe bushes into what i believe are capitive nut in the chassis.
I'm wondering if the ones which sit under the footwells in the front of the car are accessible from inside the car?!
One of mine is spinning so I am unable to tighten the bolt properly
AndrewGray 12th August 2009 03:49 PM
anyone?!
PsYcHe 12th August 2009 05:06 PM
No idea mate... have you tried taking the carpet out to look for it?
AndrewGray 12th August 2009 06:03 PM
Yeah, i'm down to a board of wood :Confused:
Going to remove that tomorrow and see what is behind it
PsYcHe 12th August 2009 07:46 PM
Is it on the bulkhead in front of the passenger's feet? Behind that are a batch of relays and power connectors :) Be careful, some big feeds there.
AndrewGray 13th August 2009 07:59 AM
yeah it is and that isnt what i wanted to hear.
I need to get past all of that to check if there is a grommit or a way i can get through to the captive nut
Conan_the_Librarian 13th August 2009 08:20 AM
Andrew,
As you probably know I took out my lump and box with the subframe and I could not see a way to get to the captive nuts. I will check later on Elsawin and EKTA and get back to you.
IT 13th August 2009 09:16 AM
Sadly we concur - We know of no way to access the captive nuts that are effectively inside the box section.... Certainly there is no way from inside the cabin, so we can save you some time there....
AndrewGray 13th August 2009 11:14 AM
Not what I wanted to hear but thanks anyway! :D ^^
